Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th May 2013, 07:23 PM   #1271
donatasm7 is offline donatasm7  Lithuania
thank's for answers and your kindness
i will start studying the things, but it's long way ahead..
Old 28th May 2013, 11:18 PM   #1272
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
A small update to my post here regarding kit parts included with the 8-channel version of the DAC...
I am now including 2-pin female headers with the Buffalo and accessory kits, so that accessories can be plugged directly into the DAC, rather then using the ribbon cable.
The ribbon cable works well, but requires special attention to wire routing, and can lead to problems. I will likely make the ribbon and it's connectors an optional accessory in the Parts Bin at some point, as I think people will prefer the male/female connector option.
I will post some pics when I get a chance to take some.
Old 30th May 2013, 03:32 PM   #1273
ericyang93 is offline ericyang93
Hi, im Eric
I plan to build a Buffalo III with USB input with this : Amanero Technologies
My question : if i only use the USB as an input, should i buy the Sidecar? Or i can install it directly on the Buffalo III board?
Thankyou for your attentions.
Eric
Old 31st May 2013, 12:47 PM   #1274
Originally Posted by ericyang93 View Post
Hi, im Eric
Eric
You can wire it directly to the Buffalo board. The Sidecar is only needed if you want to switch between I2S and S/PDIF.
Old 31st May 2013, 12:54 PM   #1275
kuribo is offline kuribo
Default what exactly do I need for an 8 channel buffalo III?
I have emailed this question directly to Twisted Pear but have received nothing in reply, so I will ask here with hopes that someone may be able to answer...
What exactly do I need from Twisted Pear to make an 8 channel Buffalo III?
Obviously I need the dac board kit, and 4 IVY/Legato outputs, but what power supplies and regulators and how many of each?
I should add that I need balanced outputs and plan to use the exa21 usb to i2s board for input.
Thanks in advance for any assistance.
Old 1st June 2013, 01:39 AM   #1276
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Sorry it must have slipped by me.
I would use two LCBPS - one for 2 IVY each
i would also suggest a LCDPS to power the DAC and any accessory you require (it has two outputs).
You will also want three dual secondary transformers: 1 x 9V 15VA and 2 x 15V 30VA
That should do the trick.
You will want to setup each IVY for 4X the normal gain.
I hope that helps. Sorry again that I missed your first request.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 1st June 2013, 01:46 AM   #1277
Cheers!
Russ
THanks....
So I only need 4 ivy total for 8 channels?
Old 1st June 2013, 01:50 AM   #1278
Russ White's Avatar
That's correct. Each IVY handles two channels.
Old 1st June 2013, 02:12 AM   #1279
Mamba315 is offline Mamba315
Was also looking into what an 8-channel (quad-stereo) BIII would entail. This would be my first DIY type build.
Seeking a very high quality, one-box 8-channel DSP & DAC solution. Was thinking of-
MiniDSP nanoDIGI 2x8 K --> SPDIF --> (4) BIII SE boards --> (4) IVYIII
OK maybe an 8X mono build would be best, but I'm trying to keep costs somewhat reasonable.
The nanoDIGI takes 5VDC power. What power supplies and transformers would be recommended on this build for best sound quality?
Old 3rd August 2013, 02:14 PM   #1280
Actualsizeaudio is offline Actualsizeaudio  United States
Actualsizeaudio's Avatar
I'd like to build this exact same thing, but with no USB, and 4 AES/EBU inputs instead. Is there an AES/EBU to i2s board somewhere. My searching hasn't found such a thing.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
