Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 30th March 2013, 07:09 PM   #1251
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
I deleted some posts just because they are really off topic.
Less pulp more juice Twisted Pear Audio.
Old 1st April 2013, 07:33 PM   #1252
pixelpusher is offline pixelpusher  United States
Default New Firmware?
I noticed a March 2013 firmware update on the Buffalo 3 page. I've not found anything mentioned here or on TP site about this. What does it address?
Old 1st April 2013, 08:16 PM   #1253
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
We just put it up there.
There is a bug that can (sometimes) lead to a mis-mapping of internal DACs if you use I2S and the software remapping for stereo instead of installing the input jumpers. This is the result of either a quirk in ES9018 and how it deals with default register settings, and the order in which the registers are set. It does not always occur, but sometimes does, so we have a new version of firmware the prevents it from ever happening. Basically, you might get three (3) internal DACs assigned to each channel, rather than four.
If you are using S/PDIF inputs, or have installed the remapping jumpers, you don't need the firmware update.
If you need at, you can either download it for free or order a new chip ($0 + shipping).
EDIT: It also affects Mono implementations, not just Stereo.
Last edited by BrianDonegan; 2nd April 2013 at 04:11 PM. Reason: Additional information
Old 2nd April 2013, 06:19 AM   #1254
bkdog is offline bkdog
Buffalo III - flexibility without compromise.
Brian, can you please post a link? I have just looked and cannot find it...
Thanks!
Old 2nd April 2013, 04:10 PM   #1255
Thanks!
The Buffalo III Digital-to-Analog Converter
On the bottom of the Buffalo-III page.
Old 8th April 2013, 11:09 PM   #1256
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Default Need a bit of help...
Put together my BIII with Legato 3.1
Tested voltages before connecting...all ok:
5.25 V for BIII rock steady.
+- 12 V for Legato 3.1.
SDTRANS had been playing for ages with SPDIF and a TDA1541 DAC so ..tested!
Now connected i2S via UFl cables...mute and lock leds cycle once on boot up them lock remains on when SDTRANS is connected so...ok.
Connected so :
SDTRANS BIII
LRCK D1
SDAT D2
DCLK DCK
GND GND
But... all i get is dead silence.
I did check balanced output Dc offset...adjusted ok to 0V.
I have set up the underside straps according to Bunpei's suggestion to emulate BII:
1 . shunt JDSD1 and JDSD2.
2 . Wire D4 to D6 on card edge.
3 . set SW2-8 ON.
I should now be able to play PCM and DSD tracks with BIII detecting automatically.
I did put the strap on ADC to connect 3.3V to PB4 not to use internal volume control.
All switches on SW1 and SW2 are OFF except SW2-8 ...that is ON.
Also soldered straps J1,J2,J3,J4,J5,J6,J7,J8,J9,J10,J11,J12
But as i say...all i get is perfect silence except tiny "pop" when lock cycles on and Off.
Since this is the first time i test a BIII i tried to research as much as possible but...no dice.
Any help welcome.
Old 9th April 2013, 12:21 AM   #1257
CeeVee's Avatar
Ok problem solved....lousy contact on UFl connectors.
Old 13th April 2013, 03:46 PM   #1258
Default Parts kit for Buffalo-III
Buffalo-III Parts Kit - Buffalo DAC - Twisted Pear Audio Support
Old 24th April 2013, 10:29 PM   #1259
Russ White's Avatar
Just a note.
Anyone who got the latest firmware update needs to know that the switch states are reversed in this release to work around a bug related to the port expander.
Otherwise the setting are the same as the integration guide.
This makes it work more like the B3SE which also used the reversed switch states for the same reason.
Sorry for not mentioning this earlier on the site.
Cheers!
Russ
Old 26th April 2013, 11:59 PM   #1260
shoom is offline shoom  Europe
Hi Russ/Brian/Leon
just plugged in the new firmware update
reversed all switches
works fine
thanks
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
