Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th February 2013, 06:27 PM   #1241
Russ White is offline Russ White  United States
Russ White's Avatar
The datasheet clearly states that the data clock should be pulled low when not in use (page 11) the sidecar does that.
If you wish to operate reliably I would suggest the same.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 6th February 2013, 06:24 AM   #1242
ENSen is offline ENSen  Sweden
Buffalo III - flexibility without compromise.
Originally Posted by BrianDonegan View Post
Sidecar also joins the DAC input channels for I2S, taking the place of the jumpers under the board, that you do not want installed for s/pdif.
If I use data 6-8 for SPDIF I can still have the jumpers since they only connects data 1-5.
Originally Posted by Russ White View Post
I am pretty sure that link is what the original question was referring too.
I think at one point I thought it *may* work. (nothing lost in trying it)
But, in short the datasheet indicates not to do it.
That was actually not where I got the idea from but if I had read the comments on that page it would have answered my question.
Originally Posted by glt View Post
Hi, I was the one that proposed such a wiring configuration and admit that I have not tested it. However, I did an experiment with the BII and was able to switch between I2S and SPDif by switching DATA 1 only. The bit-clock on the bitclock pin was live at all times.
You can try turning off the I2S source (that would shut down all the I2S signals) and switch to spdif...
As Russ said, there is no harm in trying... :-)
I have a relay board with two relays in my DAC of which I only use one so I could use the other relay to control the feed to my FIFO to do as you proposed.
Ok, if the FIFO has a pull down on its BCK output it could then work to shut it of when using SPDIF inputs. I will to some testing to see if I can get it working.
Thank you all for helping me to sort this out, it is highly appreciated.
Old 11th February 2013, 06:27 AM   #1243
I connected the FIFO via relay this weekend but still no lock on SPDIF inputs. I then found some threads on TP support forum about problems with the 4xSPDIF board when running it at 5.25. When lowering it to 4.5V the SPDIF started working.
The FIFO does not pull down the BCK when off but I still did not have any lock problems. I will do some more listening today to make sure it works. Maybe I should switch the BCK input to ground when not using the I2S, as stated in the datasheet but there is no easy way of doing that so I will probably leave it like this for a while.
Old 11th February 2013, 09:53 AM   #1244
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
I still have problems and no ideas to solve them . Maybe a seperate regulator 4,5 V. Also problems with Buffalo lock without the 4spdif. Every something is activated even by neighbours the lock cuts for a moment 1/2 second.
Old 12th February 2013, 01:25 PM   #1245
neofeed is offline neofeed  France
B-IIIse (Stereo version) is in stock now. B-III 8-channel version will be back soon. I actually have a few here I will sell soon.
Hi Brian,
Don't want to be annoying or anything but do you now when these will be available to order or pre-order ?
I'm leaving abroad for holidays friday for the next 3 weeks and wouldn't like to miss the opportunity
Thanks for your help.
Best regards,
neofeed
Old 21st February 2013, 12:44 PM   #1246
AndriyOL is offline AndriyOL  Ukraine
Interesting to know, Russ, have you suit Intel for utilising your trademark in their Ivy Bridge or such use was authorised?
If for pristine and pure adoration - it's diyAudio dedication!
Old 21st February 2013, 01:17 PM   #1247
Russ White's Avatar
Lol, well no bridge involved in my part. So I think we are both ok.
Audio
Old 17th March 2013, 02:29 PM   #1248
markusA is offline markusA  Sweden
markusA's Avatar
The BIII appears to be sold out, is there a new batch comming any time soon?
Old 18th March 2013, 01:07 PM   #1249
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
I should be opening up pre-orders for them in the next day or two. They will be back in stock in a week or so.
Old 22nd March 2013, 01:57 AM   #1250
Pre-orders are open now. I should begin shipping 7-Apr or so.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 09:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 10:46 PM
Considering a compromise mashaffer Full Range 7 15th May 2006 12:45 AM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 03:19 PM
Copyright ©1999-2017 diyAudio
