Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 19th December 2012, 10:23 AM   #1221
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Buffalo III - flexibility without compromise.
Thank you LMC I have to do something about this.
Old 19th December 2012, 05:49 PM   #1222
SCompRacer is offline SCompRacer  United States
Originally Posted by Erlend Sæterdal View Post
Hi anybody have exsperience with power supply quality influence on sound from Otto II and SPDIF 4 ?
I have an OTTO II and Teleporter in a modded Denon 3910 that exports I2S/DSD. (OTTO corrects the R and L channel reversal of DSD output as it shares two circuits with PCM). I snagged 5v off one of the existing boards in the Denon, which I presume would be clean power considering the use. It sounds fantastic.
My SPDIF 4 has only been powered by a TP LCDPS set to 4.75 w/multiple outputs connected and no issues with SQ there either.
Old 19th December 2012, 06:34 PM   #1223
Aha I see no ceramic cap on that Otto II ?
Old 19th December 2012, 07:30 PM   #1224
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
It's the first version. The C0G/NP0 cap is ideal for the application.
Old 19th December 2012, 07:39 PM   #1225
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes indeed it is. Also the current draw of the circuit itself - is a few uA (micro amps) - not even milliamps.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 19th December 2012, 07:40 PM   #1226
Ok ideal for measurements.
Old 28th December 2012, 07:43 AM   #1227
jackw is offline jackw
Hi Russ / Brian,
Wish to order a BIII but it's out of stock. Any idea when they will be back?
Old 14th January 2013, 10:20 PM   #1228
harruharru is offline harruharru  Norway
I am also interested to know when the BIII will be back in stock.
Old 14th January 2013, 10:46 PM   #1229
B-IIIse (Stereo version) is in stock now. B-III 8-channel version will be back soon. I actually have a few here I will sell soon.
Old 5th February 2013, 09:07 AM   #1230
ENSen is offline ENSen  Sweden
I have read that it should be possible to connect one I2S and three SPDIF sources directly to the BIII and using the built in mux to switch between them. Has anyone succeeded with that? The I2S works fine but I can not get the SPDIF to work. Just wanted to check if it should work so that I know if it is worth to spend more time fault tracing.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 09:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 10:46 PM
Considering a compromise mashaffer Full Range 7 15th May 2006 12:45 AM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 03:19 PM
Copyright ©1999-2017 diyAudio
