Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th December 2012, 04:30 PM   #1211
SCompRacer is offline SCompRacer  United States
Originally Posted by DQ828 View Post
It looks great, I had a similar thing happen recently, too deep in the forest to see the trees
Nobody else has a 384Hz model
Thanks for the kind words...and you are so right. The only one like it...lol
Old 17th December 2012, 04:42 PM   #1212
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Buffalo III - flexibility without compromise.
Originally Posted by c12mech View Post
DC blocking at the outputs are what is needed. I know that these can get really expensive. How do different values affect the sound? It sounds great as is but I nor the owner want to change the sound unless it is better. I thought of buying a few of the less expensive ones to try out. Just to see the kind of difference it makes.
Buy 47 uf 50 V Then they will be ok for even very low impedances. My dac use 47 uf. and can be stated as world class according to a friend.
Old 17th December 2012, 04:59 PM   #1213
Corpius is offline Corpius  Netherlands
Corpius's Avatar
That is a nice looking build. Can you give a little information about the display. I would like to have some for the next one I do for myself. I would love to be able to use a VFD for the display. I just like the look.
Can anyone suggest some good caps to use as AC coupling caps. Russ suggested 4.7uf-10uf as a size. I just need to know what anyone might be using that sounds good. Prices for such animals can be ridiculous.
The LCD is an 20x4 white on blue display with a Hitachi HD44780 LCD controller. He uses it with 'LCD ExtraIO' from electroFUN. This is basically an port extender allowing one to control the LCD using the "two-wire interface" (I2C). The controller is an Arduino Uno.
CE-Designs.net
Old 17th December 2012, 05:01 PM   #1214
Thanks for the kind words. I was just getting to enclosure choices when I decided to add the Arduino/LCD display. I was overwhelmed by it all and followed HiFiduino's recommendations for the HD44780 protocol displays.
INTRO H i F i D U I N O
Some folks, like DQ828, Corpius, gwiske, and bigpanda that can do code used different type displays. IIRC VFD displays will require external power due to the high mA requirements.
I had this big rats nest of wires on a breadboard with my Arduino/LCD until Corpius put me on to the electroFun LTD I2C LCDextra IO board. That reduced number of wires to run LCD. You do have to replace the Arduino LCD library with electroFUN's for it to work and add some lines to the code. Not sure if that works with VFD displays, but anyone that goes the LCD route should look into it. Not very expensive, like $9 US.
In regards to coupling caps, I saved some suggestions folks have offered in other threads. Mundorf ZN, Mundorf Supreme, Sonicaps. But I don't know caps like most of the folks here do.
Last edited by SCompRacer; 17th December 2012 at 05:03 PM. Reason: EDIT: Thanks Corpius, you posted while I was composing.
Old 17th December 2012, 05:30 PM   #1215
I like Mundorf ZN. What I hate is anything starting with M . Metalized caps is killing the homogeinity. They focus on the treble. And make hard midrange.
Old 17th December 2012, 05:44 PM   #1216
Corpius's Avatar
Mundorf starts with an M
CE-Designs.net
Old 17th December 2012, 05:46 PM   #1217
Haha What I meant was MKT, MKP, MKS etc. ZN is pure Polypropylene foil KP.
Old 18th December 2012, 03:36 AM   #1218
c12mech is offline c12mech  United States
c12mech's Avatar
Thanks for all that information. That will keep me busy for a while. Luckily I'm not in any hurry for it so I can take the time to get it all worked out like I want.
Old 19th December 2012, 09:02 AM   #1219
Default Power supply influence on sound from Otto II
Hi anybody have exsperience with power supply quality influence on sound from Otto II and SPDIF 4 ?
I use a 7805 and wonder why I did this because I use very good supplys for everything else.
Old 19th December 2012, 09:08 AM   #1220
leifchristensen is offline leifchristensen  Norway
noise is noise whereever you inject it imo
best
Leif
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
