Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th December 2012, 12:58 AM   #1201
SCompRacer is offline SCompRacer  United States
Originally Posted by c12mech View Post
I just finished this one for a member at head-fi. It sounds amazing and I would recommend it to anyone.
Nice build. What make of chassis is that?
Old 17th December 2012, 01:09 AM   #1202
I finally finished my dual mono BIII. Waiting for my GB Amanero USB/I2S module, and I have to finish wiring the remaining inputs.The USB input is just stuck in there as a filler. The blue LCD will eventually be replaced by a green one. Enclosure is a Hi-Fi 2000 Pesante 3U. Machining/engraving done by Hi-Fi 2000/Modushop. I did the color fill using Testors enamel.
Old 17th December 2012, 01:23 AM   #1203
nycavsr2000 is offline nycavsr2000  United States
Buffalo III - flexibility without compromise.
Nice. Did you mean 32bit/384 kHz on the front panel?
Best,
Anand.
Old 17th December 2012, 03:19 AM   #1204
Best,
Anand.
Thanks Anand. Yes, I deliberately left 'bit' out. You either know or you'll ask, right?
Old 17th December 2012, 03:25 AM   #1205
The "bit" part was not my concern. My concern was the part after that.
384 Hz
vs.
384 kHz
Anand.
Old 17th December 2012, 03:45 AM   #1206
384 Hz
vs.
384 kHz
Anand.
I'll have to go back and look at the plan........ OK, I can tell you how it happened, but it still ends with it being my fault. I had the wrong front panel size at first, started over and screwed up. I been lost in the woods and didn't notice....
Old 17th December 2012, 09:02 AM   #1207
DQ828 is offline DQ828  Australia
DQ828's Avatar
It looks great, I had a similar thing happen recently, too deep in the forest to see the trees
Nobody else has a 384Hz model
Old 17th December 2012, 12:40 PM   #1208
c12mech is offline c12mech  United States
c12mech's Avatar
That is a nice looking build. Can you give a little information about the display. I would like to have some for the next one I do for myself. I would love to be able to use a VFD for the display. I just like the look.
Can anyone suggest some good caps to use as AC coupling caps. Russ suggested 4.7uf-10uf as a size. I just need to know what anyone might be using that sounds good. Prices for such animals can be ridiculous.
Old 17th December 2012, 12:47 PM   #1209
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
As DC blocking at the balanced output or for what purpose. As dc blocking at the output of Legato Balanced I recommend Silmic II . To get better sound you have to buy very exspensive and very big caps like DCA cast .
Old 17th December 2012, 03:11 PM   #1210
c12mech's Avatar
DC blocking at the outputs are what is needed. I know that these can get really expensive. How do different values affect the sound? It sounds great as is but I nor the owner want to change the sound unless it is better. I thought of buying a few of the less expensive ones to try out. Just to see the kind of difference it makes.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
