Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 30th July 2012, 03:18 PM   #1121
bitinhvi is offline bitinhvi  Viet Nam
Send a message via Yahoo to bitinhvi
Hi Russ, I plan to build Buffalo III DAC for my hifi system. I use 02 channel and coaxial input only. Could you recommend which kit and accessory I need to order? Kit is completed one (I just have to do wiring) or there are some parts I need to solder in?
Can you ship directly to Vietnam?
Thank you.
Old 30th July 2012, 08:37 PM   #1122
LeonvB is offline LeonvB  Netherlands
A full description of parts is given in the integration guide. You'll have to solder quite some parts, basicly all through-hole parts need to be soldered.
Old 31st July 2012, 02:22 AM   #1123
Thank you LeonvB, could you please advise if below order is fit my need (02 channel, 01 single Coaxial input):
1. IVY-III Kit + One Placid HD BP Kit Combo
2. Single S/PDIF Level Converter Kit
3 Buffalo-III DAC Module (Assembled and Tested) + Trident Regulator Set (Assembled and Tested)
Old 31st July 2012, 08:26 AM   #1124
ed linssen is offline ed linssen  Netherlands
Hi Bitinhvi,
You will need a powersupply for the B3 as well. F.i. Placid HD or LCDPS.
And one 15V + one 9V transformer.
Enjoy the assembling and, of course, the listening afterwards!
Old 31st July 2012, 04:55 PM   #1125
Ed is correct, you need the first list mentioned on page 47, plus a Single S/PDIF Level Converter kit.
Old 1st August 2012, 06:24 AM   #1126
Thank you Leon, Thank you Ed.
Finaly, I decided to purchase
2. 4 input S/PDIF Level Converter Kit -> For future use
4. TOSKLINK module
5. Placid HD BP Kit for B3 because Placid HD is out of stock.
Now discussing on purchasing matter, can not wait to have it in hand
Old 1st August 2012, 08:30 AM   #1127
Hi Bitinhvi,
Your choice is correct for 1,2,3,4.
For 5, (the Buff3) you can NOT use the Placid HD BP, only the Placid HD!
A good alternative is the LCDPS. It gives you even two seperate regulators.
Or you have to wait for the Placid HD,
Cheers.
Old 1st August 2012, 08:56 AM   #1128
luisbock is offline luisbock  Portugal
I thought Placid HD BP was build with 2 Placids HD, only the negative side have diferent transistors and regulators. In that case its possible to change the negative side to make it a positive dual power supply with a 15 VAC 9V secundaries transformer to deliver 2 x 5.25V. My guess
Old 1st August 2012, 11:43 AM   #1129
Russ White is offline Russ White  United States
Russ White's Avatar
Placid HD will be back in stock soon. I have just made a board order.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 2nd August 2012, 04:39 AM   #1130
I ordered it with same thinking. I plan to use half of it (positive side) to feed B3.
Am I wrong? Please advise.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
