Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th July 2011, 03:30 PM   #101
gurubhai is offline gurubhai
thanks everyone, one more thing i would like to ask,can i use placid shunt regulated power supply with buffalo III without trident?.....
Old 16th July 2011, 04:29 PM   #102
jcarr is offline jcarr  United States
I would like to request a straightforward means to adjust the quantizer registers (bit depth).
Thanks for allowing your users to get involved!
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 16th July 2011, 06:01 PM   #103
LeonvB is offline LeonvB  Netherlands
Only if you use other 3.3V and 1.2V regulators.
Isn't that what switch 1 and 2 do?
Old 16th July 2011, 06:18 PM   #104
If modulator means the same thing as quantizer?
Normally when I see the word "modulator", I think of SMPSs and PWM, PDM, PFM or other schemes for improving efficiency / linearity.
Thanks for clarifying any semantic issues!
Old 16th July 2011, 07:21 PM   #105
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
That was just semantic slip on my part. I meant quantizier.
Less pulp more juice Twisted Pear Audio.
Old 17th July 2011, 12:34 AM   #106
Thank you, Russ!
Request for redundant feature retracted (^o^).
Old 17th July 2011, 09:45 AM   #107
atoluma is offline atoluma  France
[QUOTE=
4) turning of jitter eliminator
Russ[/QUOTE]
+1
Old 17th July 2011, 05:08 PM   #108
jgazal is offline jgazal  Brazil
Originally Posted by Russ White View Post
One other very cool feature of B-III are the jumpers which are located on the bottom on the board. They are used to connect digital or analog nets togther. Want a Stereo DAC? Ok no problem. Mono? OK 4 - channel? easy! Even 6, 1, and for the totally crazy - 1 channel with each output in exactly the same phase. All of those are possible.
So let the fun begin! Well soon anyway...
Does that mean two Buffalo III can be used in mono with only one Legato 3?
Old 17th July 2011, 09:19 PM   #109
glt is offline glt  United States
Originally Posted by atoluma View Post
+1
The jitter reduction switch doesn't quite make sense:
Using the DAC in normal mode, that is with a local clock, results in the samples being asynchronously converted and thus the jitter reduction comes from that conversion. So there is no way to turn it off because you cannot turn off the local clock.
Conversely, if you use the DAC synchronously, that is not using the local clock but feeding the appropriate clock that is generated with the data, then you cannot turn on jitter rejection because there is no ASRC.
So it seems that the switch does not do anything...
www.hifiduino.wordpress.com
Old 18th July 2011, 03:54 AM   #110
angcl is offline angcl  Singapore
When can i order this DAC ? show mid of July 2011 in the website .
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
