Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 13th April 2011, 02:12 AM   #1
ronpod is offline ronpod  United States
Default Legato output impedance
Hi Russ,
My B2-Legato feeds an active crossover as the following stage. The high frequency selving filter in the active crossover is sensitive to the output impedance of the Legato and needs to be adjusted as appropriate. Can you provide the output impedance of the Legato 2.0 and the upcoming Legato 3.1 so that I can make the adjustment to the active crossover?
Many thanks, Ron.
Old 13th April 2011, 06:21 AM   #2
if you make a research it has been talking many times about this question, here or in the support forum of TPA.
GM
Old 13th April 2011, 07:58 AM   #3
needsp is offline needsp  United Kingdom
Hi Ron
~150R. It's equal to the output impedance of the circuitry- which is high- in parallel with the I/V resistor, which is 150R
hope this helps
Paul
Old 13th April 2011, 12:42 PM   #4
Thanks for the replies GM and Paul,
The output impedance is useful immediately for the Legato 2.0 but once the L3.1 is released it will replace the L2.0 in my system. So I was hoping for some assistance from Russ to ensure my system planning will anticipate the new Legato. I would likely use the SE out.
Thanks, Ron.
Old 13th April 2011, 06:41 PM   #5
5th element's Avatar
Why not use a buffer before the shelving filter? That way it will work with whatever is before it.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 13th April 2011, 06:57 PM   #6
avr300 is offline avr300  Denmark
avr300's Avatar
Ron, are you here talking balanced or SE output ?
Join http://TurnMeUp.org
Old 13th April 2011, 07:26 PM   #7
merlin el mago's Avatar
Thanks, Ron.
Old 13th April 2011, 08:18 PM   #8
avr300's Avatar
I'm blind. Sorry.
The SE output impedance is much less, it's the output impedance of the OPAMP and in the v.3 the output diamond buffer.
Old 13th April 2011, 10:25 PM   #9
Yes, a good suggestion. But isn't the version 3 of Legato designed in the spirit of less is more? Fewer components mean less opportunity for noise and distortion to intercede. Certain the law of diminishing returns begins to apply at some point and less is then less.
The ASP that encompasses the active crossover has plenty of circuitry including opamps but I would like to keep the signal feeding it as clean as possible.
Wouldn't a buffer that maintains phase require two stages?
If the output impedance of Legato 3.1 (SE) is less then 200 ohms then I do not have to do anything to my ASP circuit; all will be right in my audio world.
Thanks, Ron.
Old 13th April 2011, 10:36 PM   #10
Do you think that the opamp and diamond buffer would provide an output impedance less then 200 ohms?
Thanks, Ron.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output Impedance jaykick Tubes / Valves 10 29th June 2006 03:52 PM
Output Impedance ijhill Digital Source 6 24th February 2003 08:42 AM
Output impedance Gunders Tubes / Valves 8 13th February 2003 07:45 PM
Page generated in 0.10345 seconds (77.19% PHP - 22.81% MySQL) with 10 queries
