Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th April 2011, 07:37 AM   #11
needsp is offline needsp  United Kingdom
Hi Ron
The output impedance of the opamp and diamond buffer will, I'm quite sure, be very low- much, much less than 200 ohms.
Paul
Old 14th April 2011, 12:06 PM   #12
natzev_i is offline natzev_i  Bulgaria
Ron, I am quoting here Russ about Legato 3.1 output impedance and abilities:
Originally Posted by Russ White View Post
Less than half an ohm(actually much less).
You shouldn't need anything after the Legato 3/3.1 when used with Buf II and Volumite. Just a power amp.
Hope this helps.
Ivo
Old 15th April 2011, 02:33 AM   #13
ronpod is offline ronpod  United States
Paul - Thanks!
Ivo - "much less" than half an ohm? Can this be?
Old 15th April 2011, 09:00 AM   #14
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by ronpod View Post
Do you think that the opamp and diamond buffer would provide an output impedance less then 200 ohms?
Thanks, Ron.
Yes, much less. As written, less than 1 ohm.
Old 15th April 2011, 12:54 PM   #15
Russ White is online now Russ White  United States
Russ White's Avatar
Yes SE output impedance of the Legato 3.1 with buffer in the audio band is basically the DCR of the output choke. Which is very tiny.
Interestingly the quote before I was actually talking about balanced input impedance. Which is also incredibly low. That is a key feature, and really important to getting the most out of the DAC.
The same low impedance is certainly true of the SE output impedance as well.
Cheers!
Russ1
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 15th April 2011, 01:03 PM   #16
Russ, please accept my apologies if I quoted you incorrectly - my mistake!
Ivo
Old 15th April 2011, 01:04 PM   #17
Russ White's Avatar
Ivo
No worries.
Audio
Old 15th April 2011, 04:43 PM   #18
Thanks for helping me understand the L3.1 specs better! So with extremely low input impedance and very low output impedance then the audiophile juice should freely leak out! The L3 will be a very nice addition to the DAC "box."
Legato output impedanceHide this!Advertise here!
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Output Impedance jaykick Tubes / Valves 10 29th June 2006 03:52 PM
Output Impedance ijhill Digital Source 6 24th February 2003 08:42 AM
Output impedance Gunders Tubes / Valves 8 13th February 2003 07:45 PM
