#61 |
I'm interested, too. I have also one question; is there a preferred input tension for this ADC?( I'm building a phono and I don't know if 1v output is good or not; my idea is phono - ADC- DSP crossover - 4 dac - 4 amplifiers )
many thanks in advance |
#62 | |
I think this ADC chip can do the RIAA for you, so you may not need the phono. |
#63 |
It can do RIAA filtering but as it is shipped, only at 48Khz. To make the RIAA work at other sample rates I will need to add custom biquad filters.
It may be better to apply such a filter later in the chain in any case.
Less pulp more juice Twisted Pear Audio. |
#64 |
I will give more details on this as I can.
#65 |
Hi Russ,
Any time frame ... ;-) Jesper
... Being mindful about sustainability also in my audio endeavors matters to me ... paying CO2 - and a quite fair pollution - compensation helps create a good listening "energy" ... |
#66 |
Working on it now, My guess is it will take my a few weeks - then I will send off for prototypes.
They actually changed the part since last I worked on this board, so I have bit of work to do. I have the new datasheet - so I am excited to get back on it.
#67 |
Hi Russ ... well, I could almost sense excitement through your last post :-)
In the meantime a question has popped up and so, just to be sure: Are you making a solution that will (also) allow for 384 kHz/24 bit recording to a PC via USB - or are your design goals something different? Best regards, Jesper
#68 |
I am indeed excited about it, as I plan to use it to create some high quality rips of my own vinyl.
![]() This module will not handle the USB side of things. ![]() There is another one for that.
#69 | |
Greetings, Jesper
#70 |
It is the USB module which is also currently under development.
It have been updated since my last prototype work since XMOS has come out with a new device.
| Thread Tools | Search this Thread |
| Endangered Audio - Gristleizer Module & New Module Line! | endangeredaudio | Vendor's Bazaar | 0 | 5th March 2010 03:03 PM |
| Noisy ADC | 5th element | Digital Line Level | 6 | 30th August 2009 10:29 PM |
| ADC Equalizer | GEirin | Solid State | 3 | 20th February 2008 02:22 PM |
| diy ADC | marksk | Analogue Source | 1 | 5th July 2007 03:40 AM |
| Diy Adc | Khron | Digital Source | 7 | 17th July 2005 11:45 AM |
