ES9102 ADC Module - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 13th September 2011, 12:43 PM   #11
Russ White's Avatar
Send a message via Yahoo to Russ White
It will use a little controller like the B3. And one could use AC2 with it. The RIAA option will definitely be available.
Less pulp more juice Twisted Pear Audio.
Old 20th September 2011, 11:43 AM   #12
lauret is offline lauret  Netherlands
lauret's Avatar
Russ, I was wondering, will you be using the same developing process as for your
USB-module, i.e. you'll show it when it's ready, or are you willing to involve the diyAudio
community in the development?
Old 20th September 2011, 02:48 PM   #13
Russ White's Avatar
I never refuse input. I have a couple of higher priorities at the moment in any case.
Old 21st September 2011, 04:08 PM   #14
Here are some things that would be nice to see implemented:
* the possibility to set the sampling freq to 44k1, 48k, 88k2,96k,176k,352k and 384k via DIP switches or by SW
* sepate digital and analog power supplies (maybe use the AVCC module)
* Both I2S and SPDIF outputs
* Two LEDs that show if clipping occurs for LE adn R channels respectively
* A very good clock
* have the possibility to disable the right or left ch datapaths and ADC
* set the clip detector level threshold
* use mono or stereo mode
* not to use the DC blocking filter as that can be done in the music software one uses
* set the IIR BW
* have some form of hardware protection at the four inputs (diodes+resistors for ex)
* no dithering
* RIAA usage possible
* have some LEDs that show the sampling freq used
* have a simple OPamp-based input sectio for all 4 inputs but it should be possible to skip this section and go directly to the hardware protection circuitry bypassing this analog section
That is about it, but there are a few interesting functionalities that I not really understand:
* it is possible to get the digital signal directly from the ADC overriding all other output settings
* set the DPLL multiplier
* select the 2nd stage ASRC IIR filter BW
/IR
Old 21st September 2011, 04:28 PM   #15
Russ White's Avatar
/IR
Nice list. I think you will be happy that most of it will be hit. I will have to do some checking on the rest.
Cheers!
Russ
Old 19th November 2011, 02:38 PM   #16
I'm sure there will be a LOT of interest. If you guys are able to make an ADC to go along with the Buffalo III, you would be the only 32-bit game in town! Except for MSBTech, but who can afford their stuff?????
Old 19th December 2011, 03:07 AM   #17
Brett's Avatar
Just bumping to also express interest.
I don't need much of a feature set, just a well implemented ADC system with SPDIF/AES out and the ability to set it to 96kHz.
Old 20th December 2011, 06:47 PM   #18
Russ White's Avatar
ESS contacted us and let us know that there is a hardware revision to the chip coming (including a change to the pin-out) so we will be delaying this module slightly.
Old 21st December 2011, 06:32 AM   #19
Brett's Avatar
That's no problem for me, but a 2012 release would be nice, so I can use it for a while before 21 Dec.
Old 21st December 2011, 06:02 PM   #20
kevinh is offline kevinh  United States
A built in USB output would be great.
Endangered Audio - Gristleizer Module & New Module Line! endangeredaudio Vendor's Bazaar 0 5th March 2010 04:03 PM
Noisy ADC 5th element Digital Line Level 6 30th August 2009 11:29 PM
ADC Equalizer GEirin Solid State 3 20th February 2008 03:22 PM
diy ADC marksk Analogue Source 1 5th July 2007 04:40 AM
Diy Adc Khron Digital Source 7 17th July 2005 12:45 PM
Copyright 1999-2017 diyAudio
