Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 30th March 2013, 02:53 AM   #81
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
Originally Posted by dutchgfx View Post
So they can spot if I missed a solder joint? I'll try in the morning I think it might be an issue with the LCBPS possibly, since it's both channels. Is it possible that low power would cause the sound to suck?
I've seen bad solder joints in photos before. It's more to do with seeing how everything's connected.
Not sure about low power. If the supplied current is not enough, I believe the LCBPS voltage would sag. Might be worth checking.
Old 30th March 2013, 01:55 PM   #82
dutchgfx is offline dutchgfx  United States
So I used my multimeter and established that FB has been shorted to GnD somehow. I checked my solders, none are touching at all. Both boards this is the issue, how should I go about trying to fix?
Old 30th March 2013, 02:03 PM   #83
Duffy Moon's Avatar
See post #79
Old 30th March 2013, 03:17 PM   #84
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Ventus EZ
Please move this conversation over to the support forum (Ventus EZ - Twisted Pear Audio Support)
Old 30th March 2013, 04:02 PM   #85
Moved, thanks all for your help!
Old 11th November 2013, 08:44 PM   #86
Well I finally finished and cased up my amp, and it sounds great. Only gripe is the voltage gain isnt enough for anything other than low impedence cans. How would you recomend I change the gain? What resitor swap should I make?
Old 21st September 2017, 05:59 PM   #87
wcwc is offline wcwc  United States
Could this headphone amp be run off a +/- 9V DC supply? That is what I have available.
With SE input, could I drive balanced and unbalanced phones? If, so what would I need?
Old 21st September 2017, 06:13 PM   #88
Ventus EZ
Yes.
It has balanced inputs, but can be used with SE input be tying -IN the GND. The outputs are only SE, however.
Ventus EZHide this!Advertise here!
Introducing Ventus Russ White Twisted Pear 97 15th May 2013 08:28 AM
ez phase plug noodle Full Range 3 14th August 2009 04:42 PM
