Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 13th November 2012, 03:43 PM   #31
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
Originally Posted by Russ White View Post
No need for another PS.
Thanks Russ. Good news indeed. Now all I need to hear is that the AC2 and USB Transport will be ready to ship next week .
Old 2nd December 2012, 01:00 AM   #32
Duffy Moon's Avatar
OK, I have my Ventus EZ. Does it need any particular configuration for bal to SE conversion? I've just used the components it comes with.
Old 2nd December 2012, 02:25 AM   #33
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I prefer the LME49990 opamp over the stock LME49710 opamp.
Old 2nd December 2012, 02:33 AM   #34
Duffy Moon's Avatar
I'm not changing opamps as I don't believe it will make much difference. I'm sure Russ chose the right one for the job.
I was thinking in terms of resistors.
Old 2nd December 2012, 03:03 AM   #35
Stock form it's already set up for BAL-SE conversion, no? This is how it's set up in the normal Ventus.
Old 2nd December 2012, 03:34 AM   #36
Duffy Moon's Avatar
I assumed it might be, but just wanted to make sure before installation.
Old 2nd December 2012, 12:26 PM   #37
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Ventus EZ
You should be fine as-is. It's basically a high-current output bal-se converter.
Old 2nd December 2012, 06:09 PM   #38
Duffy Moon's Avatar
Thanks Brian, so it has unity gain I assume. Each Ventuz EZ will b following an Ivy III, so I don't think I'll need gain. I'm currently reading up on opamps in "Electronics For Dummies" so I understand these things now.
Old 2nd December 2012, 06:54 PM   #39
Doesn't Ivy III have the Ventus EZ already built in?
Old 2nd December 2012, 07:58 PM   #40
Ventus EZ
Yes. I assume he is using it after a dual-mono Buffalo, with two IVY-IIIs.
Ventus EZHide this!Advertise here!
Introducing Ventus Russ White Twisted Pear 97 15th May 2013 08:28 AM
ez phase plug noodle Full Range 3 14th August 2009 04:42 PM
