Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th August 2011, 02:12 AM   #21
kierownik is offline kierownik  United States
kierownik's Avatar
Is it possible to modify/bridge Ventus EZ modules to drive balanced headphones? They are 600 Ohms, 70mW.
Old 14th August 2011, 02:42 PM   #22
Russ White is offline Russ White  United States
Russ White's Avatar
Absolutely, the easiest way would be if you have a balanced source such as Opus, or Buffallo, then you would simply wire one normal phase on one opposite of phase. Should work really well. And the nice thing is you could still use the +out and GND single ended.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th August 2011, 03:09 PM   #23
kierownik's Avatar
Could you post a little drawing of how to do it if possible? I don't want to make a mistake. I plan to feed it with Opus.
Old 14th August 2011, 08:54 PM   #24
glt is offline glt  United States
For each channel of the DAC:
One Ventus: DAC+ to Ventus +; DAC - to Ventus -; Gnd to Gnd
The other Ventus: DAC+ to Ventus -; Dac - to Ventus +; Gnd to Gnd
Thus one Ventus gives you the in-phase signal. The other Ventus gives you the anti-phase signal
www.hifiduino.wordpress.com
Old 14th August 2011, 09:11 PM   #25
kierownik's Avatar
I got it, thx.
Old 22nd October 2011, 02:44 PM   #26
eitancoh is offline eitancoh
Will the same work with the Ventus as well?
Old 19th November 2011, 02:33 AM   #27
Anyone?...
very tempting to add just another set of ventues and get a balanced headphones amp. (ofcourse I will have to balance my headphone..)
thanks for the time
Old 19th November 2011, 03:03 AM   #28
Russ White's Avatar
Sure. It should work just fine.
Audio
Old 13th November 2012, 01:59 AM   #29
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
I'm going dual-mono BuffaloII/IvyIII, but need SE output. If using Ventus EZ for this purpose, would I need yet another transformer and Placid BP, or could I power the boards from the 2 Placid BPs powering the IvyIIIs?
Old 13th November 2012, 03:17 PM   #30
Russ White's Avatar
No need for another PS.
Audio
Ventus EZHide this!Advertise here!
Introducing Ventus Russ White Twisted Pear 97 15th May 2013 08:28 AM
ez phase plug noodle Full Range 3 14th August 2009 04:42 PM
