Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 2nd April 2011, 11:25 AM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default I2S-S/PDIF 2:1 Mux Receiver
I'm looking for an input receiver one I2S + one or two S/PDIF output one I2S to BII, I think you don't have this product & it will be interesting to connect the future new module USB high rez input receiver with other transports like Blue-Ray, CD, DVD-A, SACD, I think can be a nice product to offer for Diyers community.
Old 2nd April 2011, 01:48 PM   #2
LeonvB is offline LeonvB  Netherlands
Look for the MRB1 in the future, or for an old OTTO.
Old 2nd April 2011, 02:24 PM   #3
Otto is for 2 I2S inputs & I need 1 I2S & 1 S/PDIF inputs?
Old 2nd April 2011, 02:28 PM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
As there are many SPDIF receiver boards you just need a MUX. Cannot see combining this with a receiver on the same board being a good idea.
Old 2nd April 2011, 02:32 PM   #5
I don't want to convert I2S in S/PDIF & after come back to convert S/PDIF in I2S when I use the HiFace.
Old 2nd April 2011, 02:50 PM   #6
The MRB1 is a simple relay module. Since the I2S & SPDIF (provided it's TTL) use the same settings on the BII module you could simply select the input you like. And let the BII handle the correct signal conversion.
Old 2nd April 2011, 03:21 PM   #7
lesuisse is offline lesuisse  Switzerland
PCM9211 from TI is the IC you are looking for but requires SW. Good luck
Old 2nd April 2011, 07:04 PM   #8
@LeonvB
@lesuisse
Thank you for the info.
I2S-S/PDIF 2:1 Mux ReceiverHide this!Advertise here!
Capture 3x (6 ch) I2S or S/PDIF macboy Digital Line Level 10 28th April 2010 07:34 PM
Twisted Pear - S/PDIF 4:1 MUX/Receiver Module (new, unused) n_maher Swap Meet 3 19th February 2009 05:57 PM
S/PDIF receiver recomendation borges Digital Line Level 9 14th October 2008 07:54 PM
SPDIF Input Receiver & MUX JHertz Digital Source 4 29th May 2003 04:22 PM
distribute S/PDIF or I2S, passive? tschrama Digital Source 14 23rd May 2003 01:22 AM
