Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 15th March 2011, 09:31 PM   #1
Default grounding spdif input with Buffalo II
I am building a Buffalo II / IVY III setup and plan to use a BNC connector for SPDIF input to the DAC. Should the body of the BNC connector be isolated from my bare-metal back panel (i.e., from chassis ground potential) with shoulder washers or some similar insulator, or can I just screw the BNC directly onto the bare chassis? I usually use a star grounding scheme and isolate all inputs and outputs from the chassis in my analogue construction projects, but I don't know if digital circuitry has different ground rules (pun intended) for best performance. Please advise.
These are mighty fine looking boards and I can't wait to get this rig running.
Old 16th March 2011, 01:51 AM   #2
Isolate the body of the BNC connector from the chassis.
Old 17th March 2011, 04:27 AM   #3
Thanks for the advice, ihear21khz. I'll bore a bigger hole in the back panel and use some nylon shoulder washers to mount the BNC connector.
Old 18th March 2011, 07:11 PM   #4
avr300 is offline avr300  Denmark
avr300's Avatar
Or use one like this:
Neutrik - Video - BNC Sockets - NBB75DFIB-P
It's isolated.
Join http://TurnMeUp.org
Old 21st March 2011, 10:50 PM   #5
Thank you, avr300; that looks like a good alternative. I know Neutrik makes high quality stuff.
Buffalo II Russ White Twisted Pear 1772 26th May 2012 10:00 PM
Buffalo II f.s. Jeffrey Davison Swap Meet 2 10th November 2010 08:19 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Buffalo II audio dropouts SPDIF/I2S noise ground problem merlin el mago Digital Line Level 9 2nd May 2010 11:21 AM
Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II orpheus Digital Source 0 9th February 2010 08:03 PM
Page generated in 0.06150 seconds (81.48% PHP - 18.52% MySQL) with 10 queries
