Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 22nd March 2011, 08:56 PM   #51
sbelyo is offline sbelyo  United States
Thanks Brian... I figured that was the answer I just wanted to make sure. I am trying to have no opamps in my rig this time.
I've found a tube BAL/SE circuit with unity gain so I'm thinking of trying that but now that I think about the ventus I may build that as well.
Darn it, you've sold another module. There goes the Camaro fund!
Old 22nd March 2011, 09:39 PM   #52
Originally Posted by BrianDonegan View Post
The onboard bal->se uses an opamp. It would take way too many components to do it discretely on the board. You can always use an external discrete unit (Ventus) driven from the balanced outputs if it's that important to you.
The major beauty of Legato 3 is all discrete for balanced OP.
Is it possible to take SE output from one of the balanced OP and ground?
Old 23rd March 2011, 12:09 AM   #53
Narla is offline Narla  Australia
sbelyo - you could always try one of the discrete opamps on the market. I'm using a Burson Audio discrete opamp to good effect.
Old 23rd March 2011, 12:35 AM   #54
I did think about that. So it does work in the legato?
Old 23rd March 2011, 01:12 AM   #55
Yes - a direct replacement for the LM4562 opamp.
Old 23rd March 2011, 08:53 AM   #56
Nobody can help me to understand what below? Are these so odd questions?
Thank you!
Originally Posted by gianmaria View Post
Hello Russ,
as an owner of different Buffalo, Ivy and Legato 1 and Legato 2, and waiting to mod both, I would kindly like to know:
- when will the schematic of Legato 3 be available?
- does the replacement of the three parallel BS250 with TP0604 have a different result in terms of measurement (ex. THD, slew rate, bandwith) on a Zload of let's say 4,7K (the ballsie inputs), or just they perform better only on lower otput Zload or both?
This is just to understand if it is worth to replace again all BS250 with these new devices.
Thank you in advance!
GM
Old 23rd March 2011, 09:24 AM   #57
acidbrain's Avatar
Gianmaria - they are normal questions, but I think Russ & Brian are very bizzy at the moment. Working on their latest gem ?
Old 23rd March 2011, 05:52 PM   #58
avr300 is offline avr300  Denmark
avr300's Avatar
Thank you!
Since you already have the L1 and L2, why not wait and get the L3. Then you could compare the 3 and report the difference.
Just a thought
Old 24th March 2011, 11:52 AM   #59
No problem at all!
I appreciate a lot the work Russ & Brian are doing for us (DYIers) and therefore probably they don't answer because they do not want to anticipate a schematic not fully tested yet.
I will patiently wait...
Thank you,
GM
Old 26th March 2011, 04:25 PM   #60
BrianDonegan's Avatar
Kits are being assembled now...
Twisted Pear Audio
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright ©1999-2013 diyAudio
