Legato 3 - Look ma! No caps! - Page 53 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 26th January 2013, 04:36 PM   #521
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by avr300 View Post
One picture = 1000' of words.
This if from an earlier Legato but the picture is principal.
Perfect!
Less pulp more juice Twisted Pear Audio.
Old 29th January 2013, 03:03 AM   #522
nvduybom's Avatar
I connect BIIISE to Legato, balanced output min is 70 mV (L) and 133 mV(R) . BSE output is 0V .
Old 30th January 2013, 03:26 AM   #523
nvduybom's Avatar
Legato measured 70 mV (L) and 133 mV(R) minimum is normal ?. Can I use 2,2uf/25V tantlum caps for balanced outputs ?.
Old 30th January 2013, 02:47 PM   #524
Russ White's Avatar
You should be able to zero out the balanced outputs
You will need to readjust again after zeroing the SE output.
You have to do this several times sometimes to get it perfect as they interact with each other.
I personally would never use a tantalum cap at the output. A film cap is a much better choice.
Old 8th March 2013, 01:48 AM   #525
Hey folks,
According to the manual-
Completely omitting the opamp based BAL/SE stage:
Omit: SW1, IC1, IC2, IC3, C17,C18,C11,C12, L1, L2, R17 – R26 and R33 – R36, as well as VR3 and VR4
It seems that C5 and C6 can be safely omitted as well. Or am I missing something?
Thanks in advance!
Alex
Old 6th April 2013, 07:10 PM   #526
acidbrain's Avatar
The Legato3 takes about 350mA, what about each IVY channel ?
Thanks, Erik.
Old 6th April 2013, 09:22 PM   #527
Russ White's Avatar
IVY III?
Old 6th April 2013, 10:13 PM   #528
acidbrain's Avatar
Ah sorry for that, I meant each I/V channel from the Legato.
Old 7th April 2013, 01:40 AM   #529
Russ White's Avatar
Roughly half...
Old 17th April 2013, 09:13 PM   #530
Default replacement caps (C1-4 and 19-22)
I have some axial relcap 2200pf foil/styrenes that I was thinking about using in all 8 positions. Probably will mount them under the board to get leads as short as possible. But I don't understand much about higher frequency circuits, and have 2 questions:
1. Advantage of radial caps is such short leads, but is this more important the the other aspects of the cap design in this circuit?
2. If the longer leads aren't a problem, I have a choice of mounting them vertically, with one short lead and one long, or flat with approximately even lead lengths. Is there an advantage to having one lead shorter, and if so, which side should be the short lead? (IC1-C4 seems like the ground side could be longer, not sure about 19-22.)
Thanks in advance!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright 1999-2017 diyAudio
