Legato 3 - Look ma! No caps! - Page 47 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 16th January 2012, 04:47 PM   #461
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes, the I/V resistors dictate the output impedance.
Less pulp more juice Twisted Pear Audio.
Old 16th January 2012, 07:17 PM   #462
Hi Russ,
I took out the big teflons and reverted back to the original 2.2nF Wimas and they, of course do not get hot any more BUT....the Legato consumption didn't change much! I measured it before teflons and after and it's around 430mA - 80mA more than you stated in the Manual. I measure the total current both Placids are supplying and then subtract all the shunted currents - is this correct? What should cause the Legato to drain more than 350mA, please?
Thank you!
Ivo
Old 16th January 2012, 07:24 PM   #463
To long leads from supply ? Maybee it will force the Legato into oscillation ?
Mine is not so hot as others report .
Old 16th January 2012, 07:39 PM   #464
Since I am powering Legato with two Placids the second one has longer twisted power leads but can they really cause oscillations, please? Is there a way I can tell without a scope?
Edit: Just to add the Legato is playing really nice - just a bit edgy and glassy sometimes but hope it will get softer after some burn-in?
Old 16th January 2012, 08:01 PM   #465
Do you have small caps 100 - 220 uf right at the output on the placids ?
Old 16th January 2012, 08:09 PM   #466
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by natzev_i View Post
Hi Russ,
Thank you!
Ivo
Yes, something might be wrong here. 430mA is at the high side. What voltages are you supplying?
To compare, I'm using 180ohm (stock is 150ohm) and is running at +-12.5v. Mine is consuming 165mA (and I like the less heat a lot more). Mine is with the buffer.
Old 16th January 2012, 08:19 PM   #467
I have two stock Placids BP - one is HD supplying the I/V stage and the other is the older 2.1.2 version for the BAL/SE part. I didn't put any additional caps on the outputs - do I need to?
All voltages are +14.5 and -14.0V and shunted currents around 60-65mA
Old 16th January 2012, 08:21 PM   #468
Originally Posted by avr300 View Post
....Mine is consuming 165mA (and I like the less heat a lot more). Mine is with the buffer.
You mean 165mA per rail and 330mA total?
Old 16th January 2012, 08:28 PM   #469
avr300's Avatar
165 mA at positive rail - and 190mA at negative rail. Measured right now
Old 16th January 2012, 08:42 PM   #470
Congratulations then, you are spot on!
As Erlend suggested I will try tomorrow shorter power leads and thicker wire and see if that will change something.
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright ©1999-2017 diyAudio
