#451 |
natzev,
I have never used caps that have ever generated any heat, but it seems very odd to me that they would get hot unless they have very low equivalent parallel resistance. Try alternate caps. Those sound like they may be bad.
Less pulp more juice Twisted Pear Audio. |
#452 |
Russ,
Thanks for the reply! I ordered some polystyrens from ebay and will try your original Wimas from the kit of course and will report back. The thing that's worrying me is is it possible the Legato to oscillate and this to lead for these caps to get hot. Or in any case they shouldn't get so hot if are not bad? Thank you! |
#453 |
Whatever caps you use need to fit in their patterns and have short leads and extremely low inductance, or they will not do what they should.
The caps we used in the design were chosen for a purpose. There is no good reason to change them.
#454 |
Yes, I will listen to you and will put the original caps - hope everything will be all right then.
Thanks! |
#455 |
#456 |
Thanks, Erlend - I know that - I just wanted to try some more "exotic" caps but obviously they didn't work right. Hope the Wimas will fix my problem.
#457 |
I have searched this thread for the legato 3.1 balanced output impedance. I wasn't able to find any information. I am not sure looking at the schematic if I can properly tell what it is. What would est the output impedance in this circuit? Is it set by the R1/R2 and R3/R4 resistors? Can anyone provide a little guidance? Thanks!
#458 | |
#459 |
I read somewhere that is was 150 ohm ! In my case with R 1-4 = 360 ohm it must be 360 then ?
#460 | |
I am running R1-4 at 180 ohms, and achieve about 1.9 volts output. I have no problems (lack of dynamics etc) running amp direct into 11K per phase in my amp. |
| Thread Tools | Search this Thread |
| Legato Tweakers Thread... | barrows | Twisted Pear | 410 | 17th March 2013 02:48 PM |
| legato buffer. | back | Twisted Pear | 5 | 14th January 2011 01:38 PM |
| Legato power and jumpers | Bassivus | Twisted Pear | 2 | 28th November 2010 06:03 PM |
| Marantz MA 500 or MA 700 schematic | krishu | Solid State | 0 | 15th March 2004 01:59 PM |
