Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 21st October 2011, 01:18 PM   #391
Thank you for the answer Russ.
Desoldering them buffers should be fun
Old 21st October 2011, 03:04 PM   #392
Default Just got...
around to installing Supertex FETs in my L-II. My subjective impression indicates a slight improvement in dynamics and very low level detail...
At some point I will upgrade to a complete L-III.
BTW, I would expect more open sound in the high frequencies considering the revised analog filter cut off on the L-III, is anyone finding that?
Old 21st October 2011, 03:13 PM   #393
BrianDonegan's Avatar
Unless you have an SMT rework setup, I would not bother trying. In that case, it may make more sense to sell the Ventus and use the money to buy some new buffers.
Twisted Pear Audio
Old 21st October 2011, 06:26 PM   #394
Russ White's Avatar
Send a message via Yahoo to Russ White
I would second what Brian said. No need to harm the Ventus, Just pick up a couple of buffers.
Less pulp more juice Twisted Pear Audio.
Old 22nd October 2011, 08:02 PM   #395
oneoclock's Avatar
I have measured another IVY Buffalo II from a friend. And my BuffaloII with LegatoIII under identical conditions. My friend Ivy is also the original components of Twisted Pear Audio.
As the tone level is very close to +8 dBu maximum sensitivity meter I have done +14 dBu max. sensitivity meter to avoid saturation problems. Although measures have more background noise.
Click the image to open in full size. Click the image to open in full size.
Old 22nd October 2011, 09:57 PM   #396
NicMac is offline NicMac  Italy
NicMac's Avatar
Which version of IVY are you testing? It says IVY 1 in the screen capture.
Anyway, your Legato III is doing pretty nice!!!
Nic
Old 22nd October 2011, 10:18 PM   #397
oneoclock's Avatar
Both are that IVY III.
Old 23rd October 2011, 03:08 AM   #398
Russ White's Avatar
I am actually not entirely surprised by the result at 0dbfs. The reason being the high output of the IVY-III first stage. There are a couple of things you could do to make it a more fair comparison.
1) Reduce the 1st stage I/V resistors by half.
or....
2) Run the test at -6dbfs.
I am really so pleased that Legato performs this well. It s really even better than I expected.
Cheers!
Russ
Old 23rd October 2011, 09:54 AM   #399
oneoclock's Avatar
IVY III:
R1, R2, R3, R4 (750/2)=360 Oh. approximately?
R13, R14, R15, R16 (180x2)= 360 Oh. approximately?
Old 23rd October 2011, 02:30 PM   #400
Russ White's Avatar
Originally Posted by oneoclock View Post
IVY III:
Yes. That combination should work well.
Remember that those resistors need be matched pairs.
Also it may be interesting to measure after the first stage as well as at the output.
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright ©1999-2013 diyAudio
