Legato 3 - Look ma! No caps! - Page 39 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 17th October 2011, 05:38 PM   #381
avr300 is offline avr300  Denmark
avr300's Avatar
Longer legs would be nice now
Old 17th October 2011, 05:39 PM   #382
oneoclock's Avatar
Originally Posted by Russ White View Post
OneOClock are those stock resistors?
Are you using 12 or 15V rails?
Yes, are the stock values.
I am using 15V
Old 17th October 2011, 05:56 PM   #383
Russ White's Avatar
Send a message via Yahoo to Russ White
Thanks oneoclock so -122dbu was H2 or THD?
Less pulp more juice Twisted Pear Audio.
Old 17th October 2011, 06:06 PM   #384
oneoclock's Avatar
H3
Legato II is 5 dB worse tan legato III
Old 17th October 2011, 06:08 PM   #385
Russ White's Avatar
Wow... That's much better than I really even hoped.
Old 17th October 2011, 06:12 PM   #386
Russ White's Avatar
The better performance from L2 to L3 could very likely be because of the better FETs and the DC coupling.
Old 17th October 2011, 06:32 PM   #387
avr300's Avatar
Sorry for the omission. I will correct that.
I did a "heads up" at support forum.
Old 17th October 2011, 08:33 PM   #388
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
Oneoclock (and sometimes with me) measured two Legatos III (Identical), one Legato II, and one IVY, one system with Salas power supplies and other with Placid's (No big differences here).
In our the listening tests, the champion is the Legato III, the Legato II sound is very close to the III but a bit veiled in comparision (very very close sound).
Happiness is a warm soldering iron
Old 21st October 2011, 11:33 AM   #389
Hi Russ, I have a question about buffers.
I have a buffer-less Legato 3.1 and, until recently, I was using it's balanced outputs going into Ventuses for balanaced to SE conversion (thus buffers were not needed anyway).
But now I've switched to using integrated BAL/SE section (sound is much better, BTW), and was wondering, is it worth transplanting those buffers from Ventuses to the Legato?
If I understood correctly, the buffers are useful if feeding headphones directly, but I'm feeding a SS amp, would I gain something sound or stability wise?
Thanks,
Fedor.
Old 21st October 2011, 11:57 AM   #390
Russ White's Avatar
I have often said and it still holds true that I cannot think of an instance where I would not install the buffers. Cheers!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright 1999-2017 diyAudio
