Legato 3 - Look ma! No caps! - Page 36 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 19th August 2011, 02:38 PM   #351
needsp is offline needsp  United Kingdom
Hi Russ
Sounds as if it would be worthwhile me changing to 2n2 then- thanks!
Old 20th August 2011, 07:19 PM   #352
zhai is offline zhai  Denmark
Hi all
I'm about to build a Buffalo DAC, and I have some questions.
I would like to use the DAC to feed both a power amp and headphones directly, using the Legato, so what would be the best way to accomplish this? Should I just hook the s/e part up to a headphone out, and if I do this, will the signal pass to both headphones and power amp (connected with balanced signal) at the same time?
Should I, instead, find some way of switching between the activation of these two signals, so that I can turn a knob on the front of the DAC?
I guess my level is about intermediate, as I have built only a few pieces of sound equipment before - DDDAC, TPA preamp and UcD power amp.
Old 20th August 2011, 07:57 PM   #353
avr300 is offline avr300  Denmark
avr300's Avatar
That's the way I do it and it works flawlessly.
Old 20th August 2011, 09:43 PM   #354
LeonvB is offline LeonvB  Netherlands
Correct. The SE out of the Legato should be powerful enough to drive most headphones.
Old 20th August 2011, 09:55 PM   #355
Anyone know how low impedance its possible to run on the balanced output ?
Old 26th August 2011, 02:58 PM   #356
MWL168 is offline MWL168  United States
Default increase SE buffer output
Hi Russ:
I can not get enough volume with my Audaze LCD 2 headphone which is rather inefficient. What can I do to increase the gain of IC1?
Thanks!
Old 3rd September 2011, 03:05 AM   #357
Default Legato 3.1 SE output gain
Hi Russ:
Based on what was stated in the Ventus headphone amp manual; I assume the gain of IC1 is R21/R17 = R22/R18 = R23/R19 = R24/R20. Is this correct?
I also have the following questions:
1. Is it better to lower the value of the resistors determining the input impedance to IC1 (R17 - R20) or raise the value of the feedback resistors (R21 - R24)?
2. If I choose to lower the value of R17 - R20, is it necessary to make the R33 - R36 the same value?
3. Do you have recommendation what resistance range I should use? Currently, using iTune on my Mac BookPro laptop as source, I have to be in the last 1/4 of adjustable range of the Volumite to get enough volume - this with the iTune's volume maxed out.
Thanks!
Old 3rd September 2011, 03:46 AM   #358
Russ White's Avatar
Send a message via Yahoo to Russ White
For best results simply adjust R21-24. Try doubling them for now.
Less pulp more juice Twisted Pear Audio.
Old 3rd September 2011, 10:08 PM   #359
Thanks Russ!
I don't have 10K resistors handy so instead I put 7.5K Caddock MK132 0.1% in R21 - R24. I still have to turn the Volumite pass 2/3 of the way but I am now getting enough volume for my headphones.
Unless you have concerns I'll just leave the Legato the way it is now.
Thanks again for your help!
Old 8th October 2011, 09:48 AM   #360
Default Legato 3 with discret opamp
Anybody know if it is possible to change the LME 49720 to a Dexa discret opamp ( the Dexa have Bipolar input cicuit ) ? I am asking because of the common feedback circuit.
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright ©1999-2017 diyAudio
