Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 24th June 2011, 11:43 AM   #281
Spev is offline Spev  United Kingdom
What 2n2 filter caps are you using there staccatiss?
Old 24th June 2011, 11:59 AM   #282
BrianDonegan's Avatar
Originally Posted by Theodosis O. View Post
How can I be sure the power amp can handle the DC from legato 3 ?
Is there any test procedure ?
I dont know if it is relevant but I had a problem when direct coupling Ventus with my power amp.
There was a hum. The problem solved when I used a tin foil capacitor.
But I prefer the sound without the capacitor
Just do not connect ground between legato and your power amp. Without ground, there is no DC, and no problems.
Twisted Pear Audio
Old 24th June 2011, 01:00 PM   #283
They were originally intended for a loudspeaker crossover, and are of course not needed for a low cutoff.
/S
Originally Posted by leifchristensen View Post
ok
but why 15ĩF? that shouldnīt be necessary to reach a low cutoff?
best
Leif
Old 24th June 2011, 01:03 PM   #284
arenīt these capacitor designs different for speaker lvl x/O and line lvl use?
should sound even better in a smaller value imo
best
Leif
Old 24th June 2011, 01:05 PM   #285
You need to know the input impedance of the next stage to calculate the correct cap value.
Twisted Pear Audio
Old 24th June 2011, 01:07 PM   #286
I know and thatīs why I react on this extremely high value
Itīs effectively a high-pass filter, right?
best
Leif
Old 24th June 2011, 01:27 PM   #287
Thanks Brian,
You mean to connect only the + and - pin of an xlr jack and not gnt pin
I will try.
Old 24th June 2011, 01:47 PM   #288
I used film and foil 1n0 polystyrenes from RIFA type PFE210.
For space reasons they are both on the underside and on the upper side.
/S
Old 24th June 2011, 01:59 PM   #289
Yep, it is a RC HP-filter of the 1st order with a cut-off at (2*pi*15u * 10k)^-1 = 0.94 Hz (-3dB). I could even use a 1uF cap but they are a bit costly and as I had three different pairs of VSF caps in the range 8u2 - 15u in my drawer, I just put the 15uF in and listened.
I have also tried the red-brown russian PIO // russian Teflon caps but the VSF is better, IMO.
/S
best
Leif
Old 24th June 2011, 01:59 PM   #290
Thanks. I've just put some rifa pfr 2n2s in last night, but I'm not convinced. Sounds a bit flat and lifeless. Will have to try the pfes. I'm trying to resist ordering relcaps as I just can't justify the cost, but the niggle to try will never go away...
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright Đ1999-2013 diyAudio
