Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th March 2011, 05:27 PM   #61
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Legato 3 - Look ma! No caps!
There will be two versions of the kit: with and without the optional SE buffers. Pricing is not yet final, but will be in a few days. The buffers are not cheap, thus the two versions. The kit with pre-mounted buffers will be roughly $25 more.
Old 26th March 2011, 05:29 PM   #62
natzev_i is offline natzev_i  Bulgaria
When will they be available for order, please?
Old 26th March 2011, 05:32 PM   #63
Once I get a substantial number of kits ready, and have the pricing finalized. I can probably get the pricing done tonight if I can steal away a little time.
Old 26th March 2011, 05:38 PM   #64
Thanks, Brian - I'll keep looking at your website.
Please, pardon my ignorance but is the SE buffered version suitable for driving headphones only or both headphones and pre/power amps, as well?
Old 26th March 2011, 05:41 PM   #65
Russ White is offline Russ White  United States
Russ White's Avatar
Absolutely.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 26th March 2011, 05:47 PM   #66
Originally Posted by Russ White View Post
Absolutely.
I suppose this means both amp and headphones which is great - thanks!
Old 26th March 2011, 05:56 PM   #67
Russ White's Avatar
Yes . At the SE outputs you have 250ma of SE output to use as you see fit.
Using the balanced outputs without caps is not going to work for everyone. I will cover this in the manual, but if you balanced amp has diode protection at the inputs, and/or cannot handle common mode DC while powered off or on, you should definitely use caps. This only applies to the balanced outputs, and those caps will not be in the path to the BAL/SE stage. If you do decide you need caps they will be external to the I/V stage, and can be fairly low value film types depending on the impedance of the next stage of course.
Those going into truly differential transformers with no tap to GND on the primary side will not need caps.
This thing is absolutely amazing into headphone. I have been listening to all of my cans, all of them from electrostatic to 600ohms sound awesome. Plenty of power to spare. Incredibly rich and realistic bass and extended but not harsh high end.
Cheers!
Russ
Audio
Old 26th March 2011, 05:56 PM   #68
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
- will the kits be shipped out with the Supertex TP0604 ?
- I have the Ventus to adjust dc to 0V and later also the Legato 3 to adjust to 0V.
Can I use both to adjust or is there a favourite, better to use one and set the other with fixed resistors?
Old 26th March 2011, 05:59 PM   #69
Russ White's Avatar
1) yes.
2) Shouldn't make much difference either way. Experiment and see which you like best.
Audio
Old 26th March 2011, 06:17 PM   #70
avr300 is offline avr300  Denmark
avr300's Avatar
What is HP_out ?
Legato 3 - Look ma! No caps!Hide this!Advertise here!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 03:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 02:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 07:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 02:59 PM
