Legato 3 - Look ma! No caps! Legato 3 - Look ma! No caps! - Page 54 - diyAudio
Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 23rd April 2013, 03:47 AM   #531
FallenAngel is offline FallenAngel  Canada
I'm having a bit of a weird issue with the Buffalo 3 / Legato 3.1 and the Kevin Gilmore Dynamid (Balanced Dynalo) - I get no sound except when I'm powering down the amp. I'm assuming this design requires the use of output caps and some protection circuit is kicking in, but I'm really unsure. The unbalanced outputs of the Legato work perfectly with a small amp I use for testing.
Any ideas?
NOTICE: Looking at the schematic of the Dynamid amp, it's running in bridge mode where Input and Ground are separated only by a resistor and all 4 channels operate independently, so it might really by an off-case scenario that it doesn't play well with Ground/Signal DC.
Old 23rd April 2013, 04:28 AM   #532
RESOLUTION: Just wired in output caps and it works like a charm.
Old 25th March 2014, 07:02 AM   #533
themystical is offline themystical  United Kingdom
My Legato 1.0.3 is not working any more and I am trying to do a bit of fault finding. The switch relay appears to earth the output of the opamp when there is no +-12V supply present. Could somebody explain the function of this and why it is desirable to do this?
I presume that if the relay/switch was removed, the Legato would function normally? What are the downsides to removing the relay/switch?
Many thanks in advance for the help
Old 25th March 2014, 01:32 PM   #534
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
The relay prevents thump at power on/off.
Less pulp more juice Twisted Pear Audio.
Old 25th March 2014, 02:01 PM   #535
Thanks Russ. Will remove it and see if I can get the Legato working again.
Old 25th March 2014, 09:31 PM   #536
Yep Legato is working fine with the switch/relay removed. Anybody know a reasonably priced source for one of these (Omron G6K-2P-DC24) as the total cost of getting it from RS here in the UK is a ridiculous 25?
Old 25th March 2014, 09:50 PM   #537
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Send me a PM.
Old 4th April 2014, 11:26 AM   #538
Now sorted, thanks very much to Brian.
Old 18th May 2014, 01:21 PM   #539
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What's the output impedance for SE output?
Old 24th May 2014, 06:24 PM   #540
AlexanderTD is offline AlexanderTD  Ukraine
Could someone please help me to make sure i'm doing it right:
i recently built Buffalo III with Legato 3.1 and while configuring Placid HD was quck and i ended with something like 520mA with 50ma being shunted, but my Legato only eats 230mA per side at -13/13V input. Isn't it kinda low? From manual i know it supposed to eat 350mA, but if i set BP to that i get 200mA+ shunted and heatsinks get pretty hot...
It does play music for 2 days now and all seem to be normal, although i have a feeling it's a bit "soft" atm and could use a bit more dynamics\attack\drive (compared to previous dac i had). I'll be getting bigger trafo soon (i have only 30VA atm) as some people suggested and maybe increase voltages to 15V on Placid BP once i'm sure about temperatures...
Legato 3 - Look ma! No caps!Hide this!Advertise here!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
Copyright ©1999-2017 diyAudio
