Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th November 2012, 10:28 PM   #501
RollE2k is offline RollE2k  Sweden
It says this module runs 12-15v, and that 15v is the "best".
Is it anyway possible to make it run even higher voltage, say 18v? and would there be any benefit doing that? (i'm just thinking it wouldn't be necessary burning 9v in the shunt-PSU i have right now, which is why i ask)
Old 13th November 2012, 03:16 PM   #502
Russ White is offline Russ White  United States
Russ White's Avatar
It is possible, you may want to tweak some resistor values. You would also need to be sure that the opamp you use for bal/se can handle it.
Personally. I would stay in the 12-15V range.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 13th November 2012, 05:33 PM   #503
I won't be using any opamps, since i will run balanced straight into my linestage (they will share box).
Hmm, then i'll maybe have to look into modifying for higher voltage, since i wouldn't want to increse sinking on the PSU.
Old 13th November 2012, 08:09 PM   #504
By the way, since these are DC-cancelling - i won't need any caps between the legato and my volcontroller going into the grid of my tubes in the line stage?
Old 16th November 2012, 03:52 AM   #505
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Legato 3 - Look ma! No caps!
Is it possible to use other resistors around the opamp to get some gain there ? Change the resistors 21-24 to 10 kohm ?
Old 16th November 2012, 01:41 PM   #506
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Yes. It's a straight forward op-amp stage, so the usual gain calculations can be used.
Old 18th November 2012, 08:16 PM   #507
By the way, current consumption is said to be 350mA. How much is it approx without the opamps?
Old 19th November 2012, 03:55 PM   #508
avr300 is offline avr300  Denmark
avr300's Avatar
Still aprox. 350mA
Old 24th November 2012, 10:55 PM   #509
necplusultra is offline necplusultra  Canada
Greetings,
so I fired up the legato3 for the first time. I set the ballanced Voltage to 0 but the SE does not fluctuate. It stays at 0 even if I turn the pots completeley left or right. Does this mean that the IC1 is blown?
Old 25th November 2012, 10:23 AM   #510
Greetings again.
I tried the opamp in an O2 and it confirms to be functionning. I am powering legato3 with salas bib with about 300ma on each +- 15 V rails. The bal section can be trimmed to offset 0 v dc. The SE section cannot be trimmed no matter what direction the wiper on vr3 vr4 are turned. I'm not using the buffer section so I jumpered j5,j6. I don't have anything populated at r25, r26, l1,L2 uc2,uc3.
ANy help would be appreciated.
Note: my system is direct with no caps so I don't want to try it out live before knowing if there is DC at the SE end
Legato 3 - Look ma! No caps!Hide this!Advertise here!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
