Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th October 2011, 05:49 PM   #361
oneoclock is offline oneoclock  Europe
oneoclock's Avatar
Hello.
The Legato 3.1 works perfectly. Has lower distortion than IVY-III circuit and sounds better, especially bass.
But the balanced output + and - features 9 v. respect to ground. I will used it with balanced DCB1 and F5X (EUVL).
As one of the advantages of both DCB1 and FX5 will be that will be coupled in continuous, capacitors employment would spoil all advantages.
To solve the problem I can think of two circuits. It is floating mass to set XLR Pin 1 to 9 v.
I have a doubt that will work best of two. And what better 0 to15 v. or -15 to 15 Volts?
Old 16th October 2011, 06:05 PM   #362
Russ White is offline Russ White  United States
Russ White's Avatar
Hmm, I am not sure you will need such a circuit at all. You should just be able to leave pin1 floating or simply GND only one end. In fact it might not be a good idea because if the possibility of a short.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 16th October 2011, 06:18 PM   #363
Russ White's Avatar
If I were going to do such a circuit I would simply put a couple of 10K(or similar value so as not to unnecessarily load the output) resistors in series across the balanced outputs and take the center(junction). Then use that for your common mode voltage (buffered). But once again you would have to be sure pin1 never made contact with common GND (say earth GND not necessarily 0V) or you would get a short.
As I said I can't think of a reason you would need to do this.
Audio
Old 16th October 2011, 07:25 PM   #364
NicMac is offline NicMac  Italy
NicMac's Avatar
Legato 3 - Look ma! No caps!
Originally Posted by oneoclock View Post
Hello.
Are you sure Legato has lower distortion than IVY?
I agree that Legato works perfectly, if it sounds better is a matter of taste, but that IVY should be shy or imprecise in bass is certainly not my impression.
Old 16th October 2011, 08:11 PM   #365
oneoclock's Avatar
I measured the armonic distortion is much lower in my circuit. It is important that they are perfectly united Q2-Q3 and Q5-Q6. This is what more reduces the harmonic distortion in my circuit.
And the bass of IVY was the best and most accurate that had ever heard ... Until I heard the Legato 3.1 on a friend's house.
Old 17th October 2011, 01:53 AM   #366
Russ White's Avatar
Hi Oneoclock.
Hmm this is very interesting to hear. I had an early version of Legato tested by a third party and it measured slightly worse (though only very slightly) in terms of dynamic range, but almost identical in terms of THD as IVY-III. Can you share your results?
Thanks! Russ
Audio
Old 17th October 2011, 01:11 PM   #367
oneoclock's Avatar
This is the armonic distorsion 1000 Hz. tone measure with my IVY.
7 dB down since the 1000 Hz tone have +7 dBu.
Tomorrow I get the measure of Legato 3.1
Old 17th October 2011, 01:16 PM   #368
Russ White's Avatar
How are you measuring? Differential? The 3rd harmonic is much higher than I have ever seen before. But this could be because of the higher level.
Audio
Old 17th October 2011, 01:55 PM   #369
Russ White's Avatar
To give you an idea, this is the result of the testing we had done on the Buf32S which is the same output stage as IVY-III.
Audio
Old 17th October 2011, 04:27 PM   #370
oneoclock's Avatar
1000 Hz. + 7 dBu. measure 7 dB down is correct.
The measures in balanced and unbalanced are very close.
The output level and measurement equipment configuration is identical to IVY
Legato III 3.1
Legato 3 - Look ma! No caps!Hide this!Advertise here!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 02:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 01:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 06:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
