Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 24th June 2011, 07:31 PM   #301
Sync is offline Sync  Serbia
Sync's Avatar
Pass AlephJ and Aleph30 amps don't work with Legato3 if gnd on xlr is lifted...
Old 29th June 2011, 07:07 PM   #302
orpheus is offline orpheus  United States
I have built a Legato 3, but haven't installed it yet, in part because I am having difficulty understanding and researching if common mode DC will damage my system.
I have active loudspeakers made by ADAM, and I have emailed them to inquire if common mode DC will work with their equipment. I think that I failed in explaining the situation to them, as they answered as if I was inquiring about offset. I would bet that it would be ok to use the Legato with my setup, but I want to ask the manufacturer to be certain.
Here is what I am thinking of writing to them in response, please let me know if I have made any errors, or if I should add anything.
The DAC I want to use has common mode DC at the balanced output, but no differential DC. At the balanced output of the DAC, there is no DC between + and -, but 7-9 volts of DC between + and Ground and - and Ground. Will the DC between + and Ground, and - and Ground cause problems for the amplifiers, or will it work since the DC between + and - cancels itself out?
Thank you for your time and assistance.
Aaron.
Old 29th June 2011, 07:13 PM   #303
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Legato 3 - Look ma! No caps!
Aaron.
I would add, "Or can I omit the signal ground all together?" As this would eliminate the DC all together. It is often not needed.
Old 29th June 2011, 07:43 PM   #304
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
May I ask a question regarding removing ground on balanced outputs? A balanced output works by keeping the signal that is equal and opposite in polarity respecting to ground, and discarding the signals that are equal in polarity and voltage.
How can you remove ground with no issues, where is your common reference?
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 29th June 2011, 07:49 PM   #305
Thanks so much! I appreciate your time and help.
Aaron
Old 29th June 2011, 07:49 PM   #306
Regi
The derived center point between the differential signals.
Old 29th June 2011, 07:55 PM   #307
regiregi22's Avatar
That's clear, thanks!
Old 1st July 2011, 12:33 AM   #308
alazira is offline alazira  United States
alazira's Avatar
Hi Brian,
So one can try without the ground and if it works great, but if it doesn't then nothing bad will happen, just no sound?
Old 1st July 2011, 01:37 AM   #309
Yes, or bad sound. (You will know.)
Old 2nd July 2011, 03:17 PM   #310
gwikse is offline gwikse  Norway
Finished my legato 3.1
Playing through some cheap headphones atm. Have never heard them sound this good though
Tried using no ground connection to my icepower 1000asp modules (with attenuator for testing purposes). I had a little background noice through the speakers. Are yours completely silent?
At start up the + - outputs measure 2mV dc but settles down to 0,0 and I was wondering what your numbers are? Do you see the same during warm up?
I had the output at 0mV initially but noticed that after a while I had aprox -2mV so I adjusted it too keep it as close to 0 as possible when warm.
Legato 3 - Look ma! No caps!Hide this!Advertise here!
Legato Tweakers Thread... barrows Twisted Pear 410 17th March 2013 03:48 PM
legato buffer. back Twisted Pear 5 14th January 2011 02:38 PM
Legato power and jumpers Bassivus Twisted Pear 2 28th November 2010 07:03 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 02:59 PM
Copyright ©1999-2017 diyAudio
