Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th December 2010, 01:22 PM   #11
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo II module does not power up
Try powering it without the firmware chip
Old 5th December 2010, 06:33 PM   #12
kamaths is offline kamaths  United States
Thanks for the reply. Is it the socketed chip on the right? I want to be sure before I do anything silly.
Old 5th December 2010, 07:26 PM   #13
avr300 is offline avr300  Denmark
avr300's Avatar
Yes it is. Labeled Atmel. Gently remove it, notice the orientation.
Old 5th December 2010, 08:53 PM   #14
tauro0221 is offline tauro0221  United States
Check the resistance at the Buffalo voltage input connector to see if you have a short in the board. Low resistance reading means you have a short some place in the Buffalo board.
Old 5th December 2010, 09:45 PM   #15
Resistance at the input connector with or without firmware chips 15kohms
Pulling the firmware chip out and reconnecting placid did not solve the problem
Old 5th December 2010, 09:53 PM   #16
Try connecting a 15K resistance to the power supply without connecting it to the Buffalo board. Check the output voltage from the power supply.
Old 5th December 2010, 09:57 PM   #17
ronpod is offline ronpod  United States
kamaths,
Your earlier series of pics included an underside shot of the BII board (no longer included). On the lower set of the riser pins (to the elevated power supply) there appeared to be a little soldering swarf; does that clean off by simply pushing it off? All remnants of the soldering process should be cleaned off with alcohol and a cotton-tipped swab. If the solder sticks and does not budge then it may be an unintended soldering bridge that may be part of your problem. I came back to your thread and wished to take a better look at that area but that pic no longer displays on my browser.
Hope this is some help,
Ron.
Old 6th December 2010, 12:10 AM   #18
It appeared to some flux residue, I cleaned the board again especially around the pins with a cotton swab dipped in Flux Off. Unfortunately no luck.
Old 6th December 2010, 12:35 AM   #19
glt is offline glt  United States
Tauro0221 has a good idea. You want to determine if the Placid is at fault.
Operating, the Placid should provide ~400 mA at 5.5V. This means (with the equation V=IR), that a resistor of ~13 ohm should simulate your current consumption. Get a bunch of resistors together and put them in parallel with (because it will get very hot) to obtain say 15 ohm. if you put 6 100 ohm resistors in parallel, you will get 100/6=16.6 ohm and 7 resistors will be 14.3 ohm. Then connect the resistors to the output of the Placid and see what happens. If the voltages of the Placid are maintained and the resistors get hot, Then the Placid is working correctly.
www.hifiduino.wordpress.com
Old 6th December 2010, 12:42 AM   #20
Russ White is offline Russ White  United States
Russ White's Avatar
measure the resistance across the caps around the voltage regulators on the Buf-II. If there is a short somewhere on the board (even after the caps) that test should show it.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Buffalo II module does not power upHide this!Advertise here!
Buffalo II Russ White Twisted Pear 1912 7th December 2017 04:35 AM
Buffalo II f.s. Jeffrey Davison Swap Meet 2 10th November 2010 09:19 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 03:51 AM
WTB Buffalo-II DAC Module fas948 Swap Meet 1 2nd April 2010 03:07 PM
