Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 3rd December 2010, 12:37 AM   #1
kamaths is offline kamaths  United States
Default Buffalo II module does not power up
Hello
I purchased a buffalo 2 dac in August and a placid supply in October 2010. I finally managed to assemble the placid supply and powered it up. I get 5.5v at the output of placid with 9 v ac in . The transformer I am using is avel which is capable of supplying 1.2 amp
When I connect the power supply to Buffalo, I do not see any leds lighting up on the Avcc module nor spdif lock. In fact the the voltage of placid drops to 1.6 Vwith buffalo dac board connected which is what I measure at DAC power input terminal as well as AVCC input . Thinking that it could be power supply issue, I used placid to power up 5v receiver section of my other TDA 1541 dac and it worked without any problem.
Am I missing something here .I was excited about this hearing this new dac. Please help
Old 3rd December 2010, 10:36 AM   #2
Russ White's Avatar
Send a message via Yahoo to Russ White
Have you tried adjusting the output current of the Placid?
Less pulp more juice Twisted Pear Audio.
Old 3rd December 2010, 12:35 PM   #3
Yes. Reads per instruction manual exactly at 0.055V across R3.
Suresh
Old 3rd December 2010, 12:39 PM   #4
Russ White's Avatar
Suresh
This is measured with the Placid connected to the load?
Old 3rd December 2010, 10:42 PM   #5
Without load, placid output 5.45V with voltage across R8 measuring 0.35v dc and voltage across R3 0.055v
When buffalo is connected, placid output drops to 1.6v and R3 drops to 0 but voltage across R8 remains same at 0.35v Dc.
Adjusting VR1 does not bring up voltage across R3 to required specs of 0.05 and above.
Old 4th December 2010, 12:20 PM   #6
avr300 is offline avr300  Denmark
avr300's Avatar
You must have a short.
Is the AVCC shunt board correctly orientated ?
Join http://TurnMeUp.org
Old 4th December 2010, 12:25 PM   #7
Yes. I looked at the pictures of other boards posted in the forum and made sure the in, ground and out are correctly oriented on the AVCC module and the main board
Old 4th December 2010, 12:29 PM   #8
avr300's Avatar
Grab a picture and attach it. Says more than 999 words.
Old 4th December 2010, 01:41 PM   #9
jrenkin is offline jrenkin  United States
Look for simple mistakes. The "short" idea os good. Check all your solder joints and make sure you have no bridges.
Also check other components, like the diodes, that are easily reversed. I found out I had put a diode in backwards on the placid and it worked, but not at the correct voltage/current until I fixed it.
Check both the placid and buffalo boards.
Old 5th December 2010, 12:21 AM   #10
Double checked placid parts .All OK
Went over both boards with magnifying glass. Nothing wrong that I could see.
Attached are some pictures of the assembly
Buffalo II Russ White Twisted Pear 1772 26th May 2012 10:00 PM
Buffalo II f.s. Jeffrey Davison Swap Meet 2 10th November 2010 08:19 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Volumite for Buffalo II? markusA Digital Line Level 15 8th April 2010 02:51 AM
WTB Buffalo-II DAC Module fas948 Swap Meet 1 2nd April 2010 02:07 PM
Page generated in 0.11183 seconds (77.16% PHP - 22.84% MySQL) with 11 queries
