#21 |
the current output of a single buffalo II is 16ma.
guys i have one question too. i don`t have i2s to feed the buffalo modules. can it be done with paraled coaxial or it would spoil the 75ohm standard? my other option is to use the 2 transformer isolated outputs from musiland. one is with rca and the other is with bnc. this will be for testing purpose only. if i like it and buy a second buffalo for myself i will change the connectors to use the same at both channels. |
#22 | ||
#23 | |
Or even "Dzień Dobry" Well this is really good question how Legato is reflecting double current from Buffalo side. In theory this would be 2x16ma about 30-32ma and this is definitely few times more that other “I output DAC” I know. And I/U stage have to be designed to work on that high output current level. At "Legato or IVY III" thread IngemarR did post simulation of Legato with some very nice results, I will try to ask him about possibility or running his simulation again with double current from Buffalo. Maybe he will find this subject interesting, and we could see how this works, at list on simulations. As for higher output level at Legato this is of cause the case, output level is higher. If this is interesting for You I can check the real situation with the scope, this actually is interesting. As for lowering Legato output level, there is very nice "Legato Tweekers" thread if I remember correctly, where this is explained by "the Legato maker" himself... As for me I "like" the higher than standard output levels, but I mod my PowerAmp, I feed directly from Legato, to be able to work with this. And for me this is another advantage of this setup. Best Regards Rosendorfer |
#24 | |
... are You sure about calling Yourself "layman"... this just doesn't relay seems to fit Your knowledge... I'm sure You will have a lot of fun while get the Buffalo.... Best Regards Rosendorfer |
#25 |
#26 | |
I am sorry I have not had to time to read the whole thread yet. It looks like you are doing well. If you need any specific questions still answered let me know. Good work! Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#27 |
i did a simulation with a Legato driven by two ESS9018, ie the current into the Legato is 32mAp-p AC at 0 dBFS. Fequency is 20 kHz.
My sim of the Legoto with one ESS9018 is here http://www.diyaudio.com/forums/twisted-pear/166975-legato-ivy-iii-outputs-buffalo-ii-11.html#post2309745 Do note that I did not change the IV resistor as per Russ recommendation. Thus, output voltage is 3.2Vrms. /IR |
#28 |
#29 |
Hi IngemarR
Thanks for Your post ..!! Your simulations are very interesting... Please correct me if I'm wrong but it seems that for lets call this: normal stereo mode with 16ma input current at Legato the simulations results are absolutely much better. The 3-rd harmonics, 60Khz with normal stereo mode we get -125,6dB and at Dual mode with 32ma input current at Legato there is -109,5dB this is like 16,1 dB difference. And THD at normal stereo mode 60kHz Up is 0,0000772% and with Dual mode 0,0003369%. So it looks that we get signal level up, but we do loose pretty much on distortion..having higher signal level. Best Regards Rosendorfer |
#30 |
If you reduce the I/V resistor by half you will get much better performance.
The reason for the increase in THD is the much larger voltage swing at the output. You could also increase the static current by reducing the 330R CCS resistors. But that may not be necessary or desirable.
| Thread Tools | Search this Thread |
| p3a dual mono? | Big gain | Solid State | 19 | 15th November 2006 10:14 AM |
| making dual mono jack from single mono jack | dubmunkey | Analog Line Level | 2 | 12th October 2006 02:16 PM |
| Why dual mono? | preiter | Chip Amps | 11 | 21st September 2006 09:37 PM |
| Dual Mono v. Stereo | Papageoff | Chip Amps | 5 | 2nd November 2004 08:50 PM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 05:10 AM |
| Page generated in 0.13396 seconds (81.68% PHP - 18.32% MySQL) with 11 queries |
