#101 |
OK Rosendorfer, the dual-mono single Legato Buffalo's up and running! No problems with the voltage, the output now matches that of my old GigaDAC. It sounds really good, certainly on a par with my old Dual-Mono setup.
Many thanks for your very good advice and help. |
#102 | |
Is the Volumite really needed to do this? If I read the integration guide correctly, then connecting the outputs opposite phase on one board and opposite phase on the other board as well should work (as long as each board has it's dip switches set for the appropriate left or right channel, and set for dual mono operation).
Instead of a single Lagato, I will be using a 1:1 transformer for my balanced to S.E. conversion, then into a tube output stage. JD Quote:
#103 |
Yes it will just as easily work for the on-board firmware. You just won't have volume control for the BII.
Less pulp more juice Twisted Pear Audio. |
#104 |
Thanks Russ.
JD |
#105 |
Hi Russ
(I posted this a little while ago, but I think it went unnoticed I'm thinking of trying out a dual mono implementation of Buffalo II, with a single Legato I/V stage. Am I right to think that a single VACC regulator per channel- one for each Buffalo board- would be preferable to the two per board used in the standard stereo implementation? I.e. a single reg for all eight now paralleled DACs? Otherwise, unless I've got this wrong, you end up with two paralleled regs feeding the DACs? If a single reg is appropriate, how much current does it need to provide? should I connect it to just one est of pcb pads, or posiion it more centrally, and feed both sets of pads? Thanks Paul |
#106 |
Paul, I would use it just as designed, trying to use a single AVCC reg for both DACs will result is nets that are far too long for good regulation.
Cheers! Russ
| Thread Tools | Search this Thread |
| p3a dual mono? | Big gain | Solid State | 19 | 15th November 2006 10:14 AM |
| making dual mono jack from single mono jack | dubmunkey | Analog Line Level | 2 | 12th October 2006 02:16 PM |
| Why dual mono? | preiter | Chip Amps | 11 | 21st September 2006 09:37 PM |
| Dual Mono v. Stereo | Papageoff | Chip Amps | 5 | 2nd November 2004 08:50 PM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 05:10 AM |
| Page generated in 0.09382 seconds (75.72% PHP - 24.28% MySQL) with 11 queries |
