Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 2nd November 2010, 08:01 AM   #81
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Should we expect the module will be as small as the current one on your website?
Old 2nd November 2010, 12:25 PM   #82
lauret is offline lauret  Netherlands
lauret's Avatar
I guess the XMOS chip will already be supported in linux, but will the ALSA driver also be able to play music on 32/384?
Old 2nd November 2010, 01:08 PM   #83
Spirit02 is offline Spirit02  Peru
lil' knight - Russ has said (on the 1st page of this thread) that expected dimensions are same as the BuffII.
Old 2nd November 2010, 03:57 PM   #84
Ah, just see it. Thanks!
Old 5th November 2010, 10:24 AM   #85
leifchristensen is offline leifchristensen  Norway
looking fw to hear this
already use batterypowered hiface-s/pdif and sounds pretty good into BII
but
why bus powered(you mean via usb?)?
best
Leif
Norway
Old 5th November 2010, 03:51 PM   #86
eitancoh is offline eitancoh
Default sample rates
Originally Posted by labjr View Post
The TP solutuion should be much better. The MiniStreamer is isochronous and only goes up to 24/96.
Also, the MiniStreamer will not sample 88.2 kHz
Will this implementation be able to sample native 88.2 and 176.4 kHz?
Old 6th November 2010, 01:06 AM   #87
LeonvB is offline LeonvB  Netherlands
I think to isolate the input from the output.
Old 6th November 2010, 03:32 AM   #88
barrows is offline barrows
Default USB Bus power...
but
best
Leif
Norway
Leif: using USB bus power does not have to be a limitation if the power is handled properly. The Ayre QB-9 (product of the year, sounds incredible, blah, blah) runs its USB receiver off of the USB bus. And I am using a Wavelength Audio Wavelink USB-SPDIF interface into my B-II which runs off of the bus power, and it sounds amazing. The designer just has to make sure that the USB bus power is appropriately filtered, and regulated, and that some kind of isolation is employed between computer and DAC.
In any case, if you are paranoid about the USB bus power, it is a simple matter to break out the power and ground leads from a USB cable and apply the 5 VDC supply of your choice.
Old 6th November 2010, 03:38 AM   #89
jkeny is offline jkeny  Ireland
Banned
Barrows,
Be careful - you cannot break out the ground from USB - it has to be connected back to the PC for the USB D+ & D- reference. So no galvanic isolation with this method, I'm afraid!
Old 6th November 2010, 03:55 AM   #90
Default Jkeny
I am well aware of what you are saying. You can still break out the ground and + from the cable and apply whatever supply you want, the ground reference has to stay intact between the computer and USB receiver, and your new supply just references the same ground. I was not suggesting that applying external power provides any (ground) isolation.
In any case, what Russ White/TPA is working on already isolates the computer from the DAC.
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 10:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 05:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 01:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 09:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 01:22 AM
