Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 22nd January 2013, 06:06 PM   #631
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
TPA - USB Transport
Originally Posted by labjr View Post
There doesn't have to be material to use sampling rates above 192 Khz. Software upsampling to higher rates can make other material sound better.
This is a debatable point. Check out the graphs on pages 10 and 11: http://www.ti.com/lit/ds/symlink/pcm1794.pdf
These are "just numbers," but higher THD and lower S/N Ratio at higher sampling rates.
I am not stating a conclusion, just food for thought.
Old 22nd January 2013, 06:19 PM   #632
labjr is offline labjr  United States
Debatable or not, as many options as possible should be available. Sampling rates are increasing. DSD is becoming popular. Seems like DXD is starting to approach the point of diminishing returns. DSD 256 is the point where the quantization noise moves out of the audio band. So higher the better as far as I can tell.
Old 22nd January 2013, 06:23 PM   #633
TPA - USB Transport
I agree, but PCM != DSD. I only point out that higher is not always better.
Old 22nd January 2013, 06:30 PM   #634
Carl_Huff is offline Carl_Huff  United States
Having spent time in real project studios I can tell you this only applies when the media is initially digitized. Upsampling after the fact gets you nothing. You simply cannot put back what was never there.
Best Regards,
Carl Huff
Old 22nd January 2013, 07:27 PM   #635
TPA - USB Transport
I think the reported increase in performance is more to do with the DAC filters employed for higher-bitrate material, not that there is more detail in the data.
Old 22nd January 2013, 08:03 PM   #636
barrows is offline barrows
Default Yes...
As Brian mentions, possible improvements in sonic performance by oversampling in software are the result of the digital filters used by the OS algorythm. For instance, take a 16/44.1 file, and oversample it to 24/352.8 in software and send the oversampled data to the B-III. Now, the B-III will still apply additional oversampling, but any of the oversampling done by the B-III will result in no additional audible artifacts, so what one hears, will be the results of the filtering/oversampling done in the computer. The advantage of this approach is that one can easily try many different types of digital filters, and decide what they think sounds best, rather than being limited by the filters incorporated in the ESS chip. This approach opens up all manner of apodizing and minimum phase approaches, all different filter slopes, etc.
Will it sound better... that is for the user to decide, but it certainly does allow for a lot of options and it is much easier to apply those options in the computer. Some software players, like HQplayer, XXHighend, and Audirvana already have a pretty good selection of different filtering approaches to choose from, and these options are only going to grow in the future.
Old 22nd January 2013, 09:57 PM   #637
I think higher is better when it's done right. But like I've said before, I think there is a point of diminishing returns. But that point is debatable. Logically it would seem to be 352/384 for PCM and DSD256.
However, Robert Watts of Chord Electronics says 768 kHz recordings sound better than 384 kHz and not because of frequency response. He says the brain can detect differences of microseconds in transients. Thus he thinks the number is somewhere around 1 Mhz.
Old 22nd January 2013, 09:59 PM   #638
TPA - USB Transport
Speakers (generally) cannot, however
Old 23rd January 2013, 12:53 PM   #639
Russ White is offline Russ White  United States
Russ White's Avatar
Also one must remember that the DAC actually measures worse in terms of both noise and distortion as the sample rate goes up... Dustin actually mentioned this himself.
I too am actually not very interested in stuff above 192Khz. Partly because there is so little of it to begin with, and a lot of that is actually not as good as more widely available material.
So in my book support for > 192Khz is still something I am interested in but is not a huge priority.
The new board is coming along well. I am so glad XMOS is still in business and designing better and better parts. This new chip is *far* better in many ways to the old one.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 23rd January 2013, 03:17 PM   #640
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Maybe you're right and I'm not debating but too many people see or hear things that are in their heads... Trust me there's many examples.
I bet you take that the same song have it well converted over from 24/768 to 24/192 make them hear then take the same song again without them knowing and tell them that it is the 768 version and all of a sudden there's more magic or the other way around and now it is not as good but the same 768 file twice!
Just saying
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
