Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 14th December 2012, 09:41 AM   #621
orangeart is offline orangeart  United Kingdom
Lol
Old 14th December 2012, 12:14 PM   #622
Russ White is offline Russ White  United States
Russ White's Avatar
Hi Bumpei,
Well - you need not wait unless you choose to.
This year has been one where my time for my audio hobby has been curtailed by a number of things. A new career position, deaths in my family, and taking care of a parent who is now alone.
I have myself gone through a couple of prototypes - so I am not idle - just not yet satisfied.
I basically have started from scratch again last month when XMOS contacted me about their new chip which is now optimized for this application - including an on-chip PHY and power management. This is a very big departure from my initial plan, but much better.
At the moment I am actually waiting on XMOS for some particulars regarding firmware and drivers. This will be a better solution than any of the existing XMOS implementations.
Jan. 1 can't come soon enough - time for a new - much better - year.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th December 2012, 01:18 PM   #623
carsten.witt is offline carsten.witt  Germany
carsten.witt's Avatar
You do not justify yourself!
And private comes before all others!
Regards and waiting ..........Carsten
Old 14th December 2012, 01:35 PM   #624
Bunpei is offline Bunpei  Japan
The long and cherished board
That leads to your sounds
Will never disappear
I've seen your post before
It always leads me here
Lead me to your sounds.
The weird windows side
That the gain dashed away
Has left a pool of pears
Twisting for the day.
Why leave me standing here?
Let me know the way.
Many times I've been thrown
And many times I've cried,
Anyway you'll never know
The many ways I've tried.
But today they lead me back
To the long, cherished board
You made me thinking here
A long, long themes are go
Don't blame me for raving here
Old 14th December 2012, 02:31 PM   #625
barrows is offline barrows
Default Thanks...
For the update Russ. I am taking my time with my new B-IIIse build, to get it "perfect" and to build it integrated with the new USB interface. I will be patient and listen to other stuff in the mean time.
I hope that you will allow for Trident(s) for the oscillators modules on the USB board, this will likely be a popular option, especially for those of use who prefer to run the B-IIIse synchronously...
Best to you for a great 2013!
Old 31st December 2012, 11:55 PM   #626
thomaspf is offline thomaspf  United States
Default USB2 high speed mode galvanic isolation
This might be interesting for a future version of this adapter. The research from Silana has apparently resulted in a workable device.
USB ISOLATOR INTEGRATED CIRCUIT WITH USB 2.0 HIGH SPEED MODE AND AUTOMATIC SPEED DETECTION - THE SILANNA GROUP PTY LTD
Cheers
Thomas
Old 1st January 2013, 05:16 PM   #627
Russ White's Avatar
Cheers
Thomas
Thanks for the heads up. I wonder if/when it will be a commercially viable product?
Audio
Old 1st January 2013, 07:43 PM   #628
Default Silanna availability
I expect right now if you contact them at the link below
High Speed Digital Isolators
Silanna is developing a range of digital isolators able to handle high data rates from 100Mb/s to several Gb/s per channel. They are being designed to outperform all products now in the market.
These isolators will provide high voltage (5kV+) galvanic isolation to a new generation of high speed data interfaces.
Furthermore, Silanna's isolators offer the option of integrating high numbers of channels into a single small footprint chip.
Contact us if you have an interest in an application for this product.
Old 22nd January 2013, 05:09 PM   #629
francolargo is offline francolargo  United States
Sounds interesting, but at some point one must finally choose which compromises to accept and push development without looking back. For me, there is no interesting program material above 192kHz, but the multi-channel aspect might be interesting paired to a Buffalo III 8 channel. I need 6 minimum - three 2-channel XMOS boards seems a little power-hungry... but doable.
Old 22nd January 2013, 05:55 PM   #630
labjr is offline labjr  United States
There doesn't have to be material to use sampling rates above 192 Khz. Software upsampling to higher rates can make other material sound better.
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
