TPA - USB Transport - Page 62 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Closed Thread
Old 18th October 2012, 01:23 AM   #611
5th element's Avatar
Originally Posted by labjr View Post
Well, I guess that would depend on how many times it has to be done. There's plenty of powerful interface chipsets available now. And sample rates are getting to the point of diminishing returns. Maybe they could do it once and we wouldn't be stuck in this perpetual upgrade cycle.
Yes but if they were going to do it like this the first time round the module would be 8-10 channels out 2 channels in, sample rates up to around 400kHz, 32 bit, with support for every format under the sun. This would end up delaying the project even further, in a world where the majority of users simply want 2 channel out PCM play back up to 192kHz.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 18th October 2012, 01:32 AM   #612
labjr is offline labjr  United States
I think chipsets from companies like rigisystems will already do most of this. They could start with 2 channels and work up to 8 with firmware.
Old 18th October 2012, 07:50 AM   #613
Where can you even get files like that? Evert time i look for hi res files i'm very disapointed by what is available. It's usually stuff from musicians without a distribution network elsewhere. Or companies set upwith the express purpose of supplying hi res stuff but the get bigger and start supplying lower res stuff so they can appeal to the mass market.
Old 18th October 2012, 03:17 PM   #614
sigpaw is offline sigpaw  United States
sigpaw's Avatar
I've been impressed with HDTracks (https://www.hdtracks.com/index.php). Not everything they sell is HD, but they are limited by what the record companies release. Some of their offerings are simply rips from previously released DVD-A albums. But many are fresh, new releases straight from the studios. Like Donald Fagen's new Sunken Condos or Diana Krall's new Glad Rag Doll. They have several releases that are remasters and hi-def digital grabs of the magnificent old Mercury Living Presence recordings, re-released Telarc recordings, etc. They also have a lot of rock released in hi-def, both old and new (many are "from scratch" re-masters).
Its still a relatively new medium so it will take time to get EVERYTHING re-sampled and released..
Old 19th October 2012, 04:37 AM   #615
Originally Posted by Russ White View Post
Hey guys!
A little status update. In August at my day job I was promoted
Congrats Russ! So, just delegate and get back on the USB module.
Old 19th October 2012, 09:11 AM   #616
JoeyGS is offline JoeyGS  Philippines
Congrats Russ on your promotion!
Am also eagerly awaiting for the new USB module and hopefully it will also work with the Buffalo II dac.
Old 16th November 2012, 06:35 PM   #617
Default Sorry Russ...
I had hoped not to bother you again on the USB interface, but I have a small personal dilema. I prefer synchronous clocking for the B-II/III, and right now I am using a USB interface which only has a fast enough MC for up to 96 KHz rates. I do have the code to allow for 2X oscillators to be mounted, so I could purchase a couple of CCHD oscillators and have enough speed for proper operation of the OSF at 176.4/192. But, I would rather wait for your USB interface if it is not going to be too long, than spend another $60 on the Crysteks...
If you could give a very general ballpark estimate on when the new interface might be ready for sale, just, sooner than 6 months, or longer than 6 months I would be very appreciative. If you just do not know, of course that is OK.
Old 16th November 2012, 06:44 PM   #618
Russ White's Avatar
Send a message via Yahoo to Russ White
Its fine.
I am actually glad you brought it up.
XMOS has a new *much better* part than what I had previously designed for. This one has the PHY and the fiddly bits of power management on the chip. It also is more powerful.
So I have retooled for the new part. I am getting advice and information from XMOS on using the new part even today.
I have always planned on using 40+Mhz clocks. I still plan on it.
I will be able to give a better ballpark after I get more details from XMOS.
Having the PHY at the chip is a huge win.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 16th November 2012, 06:50 PM   #619
Russ White's Avatar
The other bit of good news is that while I still have a very demanding day job, things are leveling out a bit, and I am finding more time for the hobby I enjoy so much.
Old 14th December 2012, 10:21 AM   #620
Bunpei is offline Bunpei  Japan
How many years must a man wait for
Before he gets a new USB ?
How many XMOS must White have failed
Before he ships it in the end ?
The answer my friend is Brian' in the mind.
The answer is Russ' in the mind.
Closed Thread
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 10:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 05:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 01:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 09:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 01:22 AM
Copyright 1999-2017 diyAudio
