Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Closed Thread
Old 3rd October 2012, 03:06 PM   #591
Russ White's Avatar
Send a message via Yahoo to Russ White
Yeah I am just saying to do it would require custom firmware. I am sure it is possible.
For everyone else out there DoP transmits DSD data over PCM.
Honestly - it sounds interresting, but its not a huge priority for me to start. But it could easily be added by the user since we will expose the JTAG interface.
If we find reasons to update the firmware people can apply such updates (or optional firmware) themselves.
Less pulp more juice Twisted Pear Audio.
Old 3rd October 2012, 03:06 PM   #592
Default I hope...
that the TPA USB solution will also have single ended I2S output on U.FL for those of us who may want to place the board in close contact with a DAC board without the LVDS signaling.
I prefer to keep everything in one chassis for simplicity.
Old 3rd October 2012, 03:07 PM   #593
Russ White's Avatar
It will.
Old 6th October 2012, 03:07 PM   #594
Default Thanks...
Russ! I will try and not bother you anymore, such that you can devote your "free" time to getting this board finalized.
Old 6th October 2012, 03:40 PM   #595
Russ White's Avatar
Thanks. I am actually working on it right now (plus about 3 other boards to get made)
We have a couple of skunkworks projects Brian and I will announce when they are thoroughly tested.
Old 13th October 2012, 04:53 PM   #596
If someone were cutting holes on a rear panel and wanted to have it ready to mount, would they go with type A or B USB?
Old 13th October 2012, 09:14 PM   #597
LeonvB is offline LeonvB  Netherlands
B if you want to connect the DAC to a PC. A if it is a PC-like streamer, and you want to connect a drive to it.
Old 13th October 2012, 09:38 PM   #598
You could do what I do and cut a standard Neutrik hole. Then you can fit any socket.
Old 15th October 2012, 10:40 PM   #599
Thanks Leon.
10-4 on that! I have multiple Neutrik's here and they will be on the back panel if/when chassis design is ever finished. I was planning on USB alongside the Teleporter above four S/PDIF inputs and letting OTTO II switch I2S inputs to the Sidecar to keep the I2S wiring short.
Old 16th October 2012, 09:00 AM   #600
Take a look at those. The hole is larger than neutric but very solid and well isolated. Connection can be with molex type connector, not usb jack, PX0843/B Bulgin | Mouser
Closed Thread
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
Copyright ©1999-2013 diyAudio
