Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Closed Thread
Old 29th September 2012, 01:06 PM   #581
I prefer TPA keep their works confidential like Apple. Better to be excited by a real released product than being excited about vapor ware...
I bought the BII back in 2010 after TPA indicated that they worked hard on a USB-interface. In my part of the world 'hard work' means 'results' will be archived soon.
After 2 years my BII died and I bought the ultimate solution dual BIII, dual Legato, 5 shunt regulator PSUs and more. Afterwards I waited for months to get some info about the USB-interface from TPA, not even the PCB size could I get information about so I couldn't order a custom made cabinet for the new DAC.
So I bought a new Italian USB-interface at a very reasonable cost and now just waiting for a custom made chassis to arrive to build the ultimate DAC (for me at least).
During the 2 year period TPA continued to develop other things and even updated shunt regulators and the B-DAC. But no sight of an USB-interface from TPA...which was the reason I bought the BII back in 2010... Am I pissed? Sort of.
I know that TPA work in their spare time but if I were in their pants I wouldn't indicate that I was working hard on something without giving a release date for the product... You never get a second chance to make a first impression.
That said TPA makes the most serious DIY products of their kind and the kits are impressive! It takes a h*ll lot of time to put small labels on components to make the life easier for the customer to build the kits.
"People can't do what they should: room acoustics and speaker design - so they do what they can: new amps, cables etc." (Lidia)
Old 30th September 2012, 12:29 AM   #582
Russ White's Avatar
Send a message via Yahoo to Russ White
TPA is not anything close to a company like Apple. It is a couple of DIY enthusiasts working in our spare time to bring cool stuff to people like you.
Remember this is a hobby for us too and priorities sometimes shift.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 30th September 2012, 12:45 AM   #583
Originally Posted by Russ White View Post
TPA is not anything close to a ocmpany like Apple.
A good thing too. I'll happily give money to TP, but never a penny to Apple.
It seems that Russ doesn't tend to announce new products until they're close to being available now, which avoids the issue of delay.
Old 30th September 2012, 12:50 AM   #584
Russ White's Avatar
Thanks for the support.
I acknowlege that we have probably been optimisitc about talking about releasing the new USB module.
But keep this in mind... I have already built a few prototypes and testef several ideas - some of which are XMOS based, but not all.
We just are not comfortable releasing what we have tried - just yet.
I am sorry if anyone is put off by the delay. It is not our intention to offend. It is our intention to produce sometyhing that will sound as good for you as it does for us.
Cheers!
Russ
Old 30th September 2012, 02:52 AM   #585
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
Anything worth having , is worth waiting for.
Old 30th September 2012, 10:28 PM   #586
Russ White's Avatar
Just let you guys see I am still actively working on this. This is a new layout I am working on. Not all of the components are shown - and some are on the bottom.
The dimensions may change. The board as shown is design to slip into a case - with the LEDs in front, and the connectors on the back.
Note it has a teleporter compatible LVDS output.
Old 1st October 2012, 01:48 PM   #587
NicMac is offline NicMac  Italy
NicMac's Avatar
I.e. with a LVDS transmitter onboard?
Output both I2S and DSD - and send a signal to BIII SE telling it to change registers accordingly?
Nic
Old 3rd October 2012, 02:49 PM   #588
Default The...
Nic
ESS 9018 will auto select for I2S/DSD when properly set up to do so. The only thing you "might" want to change woudl be the filters, but this is not really necessary to play DSD. I built a B-III DAC for a friend, and set the inputs up in the same config as on the B-II, and he has no problem playing back both DSD and PCM through the same (I2S) input path. He is using a USB interface which multiplexes dSD and I2S on the same output to suit...
Old 3rd October 2012, 02:52 PM   #589
Russ White's Avatar
As far as I know the XMOS firmware does not support DSD.
Old 3rd October 2012, 03:00 PM   #590
Default Russ...
I could not find my link, sorry, but there are those who do have the XMOS chip working with DSD, that is by the DoP protocals. My understandning is that doing this requires writing new code, but some of the developments are shared as open source.
here's one:
http://www.xcore.com/projects/dsd-audio-over-usb
Closed Thread
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
Copyright ©1999-2013 diyAudio
