TPA - USB Transport - Page 58 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Closed Thread
Old 26th August 2012, 06:47 PM   #571
Default I...
Originally Posted by gioz View Post
any chance to have synchronous clock from usb transport to buffalo 3 ??
thank
Am almost certain Russ' design will support (optional) synchronous clocking. He has mentioned many times that he likes the sound of the B-III with synchronous clocking.
Old 26th August 2012, 08:54 PM   #572
bluntje is offline bluntje  Netherlands
Originally Posted by barrows View Post
I would suspect that the I2S feed from the R pi would be pretty suspect... as the clock generated onboard the card could not be very clean. It will probably be much better to use a really good USB-I2S solution with a dedicated low noise power supply.
Still awaiting Russ' USB-I2S card... Using another solution right now, and am debating whether to upgrade the oscillators (CCHD series) to 2x speed for better synchronous clocking results with the B-II. Right now I am providing masterclock to the B-II at less than the ideal rate for 24/176.4 and 24/192... Still sounds great though... I would rather wait for Russ' solution, which I presume will have the necessary clock rate for best performance with the ESS 9018, than go to all the trouble and expense of upgrading the clocks on my present card...
Thanks for your input, there doesn't seem to be much support for it anyway, perhaps for that same reason. Am now storing my songs on a thunderbolt SSD for the time being. Sounds quite a lot better than from internal hard drive. Keeps me satisfied for now
Lets just enjoy the wait, knowing great things will be revealed at the end
Old 27th August 2012, 03:30 AM   #573
pinnocchio's Avatar
I don't know how the sound could be better using an SSD on Thunderbolt than Internal HDD... Really???
There's not enough latency from either media let alone the file size which is a joke to a HDD.
Are you sure you did not change other components in the chain which would account for this?
I'm really not buying into this
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 27th August 2012, 06:36 AM   #574
Do
It looks like its constantly reading the file when playing music, maybe thats why? And I suspect there are more factors other than latency, for example I also turn off my internal hdd when playing music because theres another ssd inside running the OS
Did you know you can hook up a usb dac to an ipad by a camera connector? If you happen to have both, please try it out. That is how I listened to music at first and noticed the sound was less clean and less quiet when I went to play music from my computer. Now with the files on the external ssd the sound is much cleaner and much quieter again and its not because my ears have gotten cleaner and quieter
Old 27th August 2012, 01:51 PM   #575
pinnocchio's Avatar
The important thing is that you're satisfied!
Do
Old 28th September 2012, 03:06 PM   #576
Russ, I wonder if you could give us another update on expected timeframe for this?
Cheers!
Old 28th September 2012, 04:18 PM   #577
Banned
I gave up after waiting for more than 2 years... Just bought a USB-interface from Italy...
Old 28th September 2012, 11:38 PM   #578
+10000000!!!
Old 28th September 2012, 11:45 PM   #579
Yes, already using other USB interface with DSD64/128, 384kHz PCM already....
Old 29th September 2012, 11:33 AM   #580
jgazal is offline jgazal  Brazil
If we keep this destructive criticism, there will be no opportunity to suggest functionalities during product development. TPA will prefer to keep new works confidential.
Closed Thread
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
Copyright 1999-2017 diyAudio
