TPA - USB Transport - Page 57 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Closed Thread
Old 22nd June 2012, 02:16 AM   #561
Russ White's Avatar
Send a message via Yahoo to Russ White
It is currently designed to be bus powered, or externally powered. So 5V in. I will need to get back to you on current draw.
Less pulp more juice Twisted Pear Audio.
Old 22nd June 2012, 11:43 AM   #562
merlin el mago's Avatar
Many thanks Russ, waiting the current draw. Estimated release?
Old 6th August 2012, 01:42 PM   #563
bluntje is offline bluntje  Netherlands
Hi Russ, any news? I have received my raspberry pi and am weighing my options. It seems like I can get an i2s signal directly from the r-pi, but it looks like quite a bit of coding and I'm not sure how that will perform.
Maarten
Old 24th August 2012, 04:30 PM   #564
Default Eagerly awaiting...
Maarten
I would suspect that the I2S feed from the R pi would be pretty suspect... as the clock generated onboard the card could not be very clean. It will probably be much better to use a really good USB-I2S solution with a dedicated low noise power supply.
Still awaiting Russ' USB-I2S card... Using another solution right now, and am debating whether to upgrade the oscillators (CCHD series) to 2x speed for better synchronous clocking results with the B-II. Right now I am providing masterclock to the B-II at less than the ideal rate for 24/176.4 and 24/192... Still sounds great though... I would rather wait for Russ' solution, which I presume will have the necessary clock rate for best performance with the ESS 9018, than go to all the trouble and expense of upgrading the clocks on my present card...
Old 25th August 2012, 02:32 PM   #565
amix is offline amix  Hungary
It would be nice to see some serious progress. Having a high-end DAC without high-end USB these days is pretty devastating to my feelings. ;-/
Old 25th August 2012, 06:04 PM   #566
Banned
I second that
Old 25th August 2012, 07:29 PM   #567
Russ White's Avatar
I have made some excellent progress, but I also have 3 new modules we are testing (that were in flight prior to this latest design).
The new things we are working on all work hand in hand. As soon as these are tested I will be ordering prototypes of the version of the USB module we will be making available.
The success of one thing helps move along the progress of the other.
Old 26th August 2012, 12:02 AM   #568
Duffy Moon's Avatar
Guessing (hoping!) that one of those is the long-awaited AC2.
Old 26th August 2012, 02:37 PM   #569
Macsel is offline Macsel  Netherlands
... but I also have 3 new modules we are testing (that were in flight prior to this latest design).
The new things we are working on all work hand in hand....
Can you give us an extra hint?
Old 26th August 2012, 07:10 PM   #570
gioz is online now gioz  Italy
gioz's Avatar
any chance to have synchronous clock from usb transport to buffalo 3 ??
thank
Closed Thread
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 10:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 05:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 01:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 09:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 01:22 AM
Copyright 1999-2017 diyAudio
