#551 |
After having to take care of some pressing business I am getting more design time lately. I have a pretty busy month of May lined up, but I am hoping to get a finalized design tested around June.
![]() I hope you all understand the delay. This is after all something I do for joy - it is my hobby. I have to fit it in around my busy job and the rest of my life. ![]() The same is of course true for Brian.
Less pulp more juice Twisted Pear Audio. |
#552 |
Brian and Russ, you are making wonderfull work and it is hard to believe, that it is your hobby
#553 |
I'm sure that I'm not the only fan that is looking forward to the final product. This fan would rather wait for your best device than accept a lesser, albeit sooner, product.
Given that, I was particularly pleased with my BII / USB Receiver (via S/PDIF) last night while listening to the internet version of KUVO-Denver during an offbeat jazz show. I did more than one double-take, thinking 'wow, that sounds like the musicians are here in my room!' Precious moments - thanks again. - David |
#554 |
I wish I would make my obbligations as good as you make your hobbies :-)
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#555 | |
#556 |
I seem to remember Russ commented that the XMOS MCU is rather power hungry so the power supply needs to be able to supply some 500mA.
I made sure I have a sufficiently dimensioned power supply... Cheers Thomas |
#557 |
I am looking forward to seeing this. It would be nice if it were a drop in replacement but if not that's no deal breaker by any means.
#558 |
Russ/Brian,
Will the board outline be the same for the upcoming USB module as for the current USB Receiver Module? Nice to know as I'm about to order a custom made chassis.
"People can't do what they should: room acoustics and speaker design - so they do what they can: new amps, cables etc." (Lidia) |
#559 |
Hi Russ,
Just wondering if this board will work with your up comming ADC product as a transport TO the computer for recording? Or if that feature could be put into the next version? |
#560 |
Do you know voltage & current consumption for the new USB Transport?
| Thread Tools | Search this Thread |
| TPA metronome and Ivy modules | woodturner-fran | Swap Meet | 7 | 29th January 2010 09:11 PM |
| TPA COD parts | nikongod | Swap Meet | 6 | 8th January 2010 04:07 PM |
| A SD/USB/Ethernet transport | jkeny | Digital Line Level | 8 | 25th September 2009 12:20 PM |
| Tpa 3122 help | kkchunghk | Class D | 2 | 28th August 2009 08:44 AM |
| Maybe have a CD transport source USB to drive a USB DAC? | wa2ise | Digital Source | 0 | 6th February 2007 12:22 AM |
