Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 19th April 2012, 09:15 PM   #521
sinski is offline sinski
Hmm, no USB to i2s ... another BII owner is dissapointed.
Do i understand it right ? The work on the USB module has been stopped and something like Squeezebox on raspberry pi got a priority ?
Even if this kind of device will appear, what about software to control it ?
What about remote control - Android app ?
Old 20th April 2012, 09:39 AM   #522
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
The interesting fact is how to connect it without already having released the USB module
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 20th April 2012, 12:52 PM   #523
OllBoll is offline OllBoll  Sweden
If it's based on MPD which when you already use linux would be the obvious choice that problem is solved already.
MPD is a network based server-client music player where there are working and polished clients for almost all platforms imaginable, so no problem for iOS android windows OSX or if you run linux. http://mpd.wikia.com/wiki/Clients
( I use MPD myself and has done for years though I'm currently only using it locally though I have plans to move it to an external player.)
Old 20th April 2012, 01:56 PM   #524
Russ White is offline Russ White  United States
Russ White's Avatar
Hey Guys, I just want to be clear. I am *not* canning the USB project!!! Far from it.
I know its been a long time coming but I have to work my design time around my day job.
The Linux host project will be a separate project I just think it has some better long term prospects that is all.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 20th April 2012, 02:17 PM   #525
OK, i will wait for usb interface
Something like raspbery pi with one 2.5" usb drive for music library connected to Buffalo with usb-i2s ? or ?
Some more details will be great , or it is a top secret project ...
I am sure many (not only diy) audiophiles will welcome a product similar to Squeezebox Touch, but without display (for the configuration at the begining one can connect keyboard and display), with i2s output ? (extra TP pcb ?), based on raspberry and dedicated only to non-compromised stereo music reproduction.
Old 20th April 2012, 02:59 PM   #526
barrows is offline barrows
Default Thanks...
Russ, it is a relief to hear that you plan on completing the USB receiver project.
To those who think currently available solutions are adequate/best: my suspicion is that the TPA USB solution will be better than the solutions currently available for us two channel guys (better oscillators, possibility of using new Tridents for power supplies, etc). Although some existing products are quite good, it is not hard to see how they could be improved in terms of clocking and power supplies (an area where TPA is known to not compromise).
As someone using voyage/mpd now, I am also very interested that Russ is working on his own host solution, this is a really cool development, as he can probably concentrate mostly on the hardware side, and leverage the good work already done by the mpd folks. A simple, low power host running mpd and controlled over LAN made for DIY use is a really cool possibility.
Old 20th April 2012, 03:05 PM   #527
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
I assume a network-based implementation as mentioned above.
I'm confused - how would one navigate and choose tracks without a display?
I wonder - is MPD or similar, inherently superior to a USB-i2s conversion? If so, in what way?
Old 20th April 2012, 03:08 PM   #528
You can navigate and choose tracks using some smartphone app. No display is necessary, maybe only for the initial configration.
I think that TP developpers should start another thread dedicated to this new "TP-squeezebox?-raspberrypi?" project, than we can all discuss about it
Old 20th April 2012, 03:20 PM   #529
Duffy Moon's Avatar
What if one doesn't have a smartphone (i.e. me)?
If one has a smartphone - why not play music from that? Isn't Android a form of Linux?
Old 20th April 2012, 03:21 PM   #530
Default mpd
mpd is a music player which runs on linux OS. It does not necessarily preclude a USB-I2S interface for the DAC, currently I use a custom music server with a dedicated USB output card, to a B-II based DAC with a USB receiver.
But Russ could make a direct host with I2S output (via the daughter card he mentioned) skipping USB.
mpd is typically controlled by a client via LAN (usually wifi). the beauty of this approach is that Russ does not have to develop music player software, or client software, as this already exists and works very well. I use the Mpad app, running on an Ipad to control my server, and it works flawlessly. There are various clients available to control mpd based players, which will run on smart phones and various tablets, or laptops.
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 10:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 05:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 01:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 09:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 01:22 AM
