Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 1st February 2012, 02:00 PM   #461
Default Russ...
I suspect it will be well worth the wait! I have an interim solution, so it is easier for me to be patient, but I am expecting great thinmgs from your XMOS implementation, very excited...
I am hoping for DSD support, perhaps via the dCS 24/176.4 packing method-it seems like this might be possible with the XMOS chip...
Old 1st February 2012, 04:08 PM   #462
adelias is offline adelias  Greece
The dCS spec for DSD with XMOS is not only possible but it is already available.
I've been beta testing it for a while now using mpd compiled with dCS spec DSD support. You can check it out at XCore.
Old 26th February 2012, 01:10 PM   #463
Russ,
I am making room in my new BIII case for just the Teleporter module to handle the future USB device you are working on. I have read that you may include the ability to synchronize the master clock on the BIII with the output rate of the USB device? I planned on putting the USB converter by my computer source and then run the CAT5 line up to the DAC. Will I be losing any functionality doing it this way. Thanks.
Old 27th February 2012, 04:13 PM   #464
MtBiker is offline MtBiker  United States
MtBiker's Avatar
You could also just run a long USB cable. I have a TP PCM2707 USB DAC now fed by a 20ft $2 USB cable and it works fine.
Old 27th February 2012, 04:26 PM   #465
BrianDonegan's Avatar
That will depend on the the USB bus controller of your PC... some will have the juice for it, and others will not. Incidentally, TI recommends no more than 6' of cable for the PCM270x series.
Twisted Pear Audio
Old 27th February 2012, 07:56 PM   #466
Brian,
Could you please answer my original question. Will running the teleporter from a remotely located box with you USB converter force me to lose some functionality?
john
Old 27th February 2012, 08:01 PM   #467
You should not lose any functionality that way. You will just supply the master clock via one of the teleporter lines.
Twisted Pear Audio
Old 27th February 2012, 09:11 PM   #468
Brian,
Thanks, now I can complete this thing once and for all. One of the problems with your stuff is the nagging feeling that I will miss the next improvement if I finish the project now. On the other hand that is the great thing about what you guys do, you never stand still.
John
Old 8th March 2012, 06:39 AM   #469
Brian - will there be provision to adjust the Buffalo volume control from this product?
Ideally I'd like a volume control accessible from windows that directly controls the buffalo volume level.
Phil
Buffalo II/HD250
Old 8th March 2012, 04:14 PM   #470
OllBoll is online now OllBoll  Sweden
About volume control, I've been thinking about saying this a while and here it is at last =)
I argued earlier in this thread of how the interface should be connectable to the joshua tree and how this was better than simply using digital software domain volume in the OS. After doing tests and calculations I've come to the conclusion that you Russ and Brian were right and digital volume is far superior.
24bit is good enough to reduce lots without losing SQ.
Only case I still halfly argue that touching volume management would be useful is if the internal bit depth was increased to 32bit: The TPA receives standard 24bit from the OS, converts to 32bit, attenuates in 32bit according to instructions by the OS and then sends to say the buffalo. But even this would probably be overkill since except in very extreme cases 24bit is enough and some more.
I've been thinking about writing together a thread or article where I present my proof of why 24bit is enough even when reducing bit depth by attenuation in such a way that anyone similar to me that believed digital attenuation to be bad for SQ can be convinced otherwise. And if they still don't believe the article they can follow easy steps and test and listen (and measure) for themselves =)
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
Page generated in 0.10309 seconds (86.41% PHP - 13.59% MySQL) with 11 queries
