Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 27th October 2010, 07:44 PM   #21
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by ichiban View Post
Russ,
Have you considered incorporating an ADuM4160 USB Isolator as a front end?
I've used that ahead of a Musiland USB to SP/DIF into my SABRE and
noticed an improvement in sonics.
I looked into it briefly, but since it is limited to full speed it won't work for this application. I need high speed USB 2.0 to support the sample rates I want.
I have a much better plan for isolation. But I am not going to reveal it just yet.
Less pulp more juice Twisted Pear Audio.
Old 27th October 2010, 07:59 PM   #22
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
Originally Posted by Russ White View Post
I looked into it briefly, but .............
Excellent!
Old 27th October 2010, 07:59 PM   #23
neb001 is offline neb001  United States
I'm highly interested in your XMOS implementation, Russ. Looking forward to it!
If you need any beta testers, feel free to contact me
Old 27th October 2010, 09:26 PM   #24
glt is offline glt  United States
Will it have i2c?
www.hifiduino.wordpress.com
Old 27th October 2010, 11:22 PM   #25
Russ White's Avatar
Originally Posted by glt View Post
Will it have i2c?
Do you want it to...?
Old 28th October 2010, 06:23 AM   #26
orpheus is offline orpheus  United States
First I want to thank you for sharing your work with all of us, I enjoy listening to my Buffalo II.
I looked at the XMOS website, and have a small request that you might consider.
Would it be possible to have a female USB input on the module, instead of male, so that the USB cable can be plugged into the DAC chassis with no intermediary S/PDIF or CAT cable?
You might already be intending to design the module this way, since you are going to have i2s output, but I thought I would ask. It doesn't make sense to me that the M2Tech and other modules are designed so that the conversion to S/PDIF takes place next to the computer, and then S/PDIF carries the signal to the DAC, when the USB cable would be a better choice to run all the way to the DAC, and then have very short connections to the DAC from the module.
Thank you again for sharing your work, I would not be able to afford digital with the sound quality and flexibility (DSD!) I get with the Buffalo DAC if not for Twisted Pear Audio.
Best,
Aaron.
Old 28th October 2010, 01:56 PM   #27
I don't know... maybe read information such as sampling rate? or select a song from the usb stick? :-)
Old 28th October 2010, 05:26 PM   #28
LeonvB is offline LeonvB  Netherlands
Actually I would prefer an off-board connector, so the user can select their prefered mounting type/method and no board would need to be replaced when the USB port is damaged. Also mounting it into a case gets much easier as you could simply drill a round hole for fi. a Neutrik USB connector.
I don't see the use of this: it's USB using a processor, but I doubt it'll be a full blown embedded computer board. Reading sample rate and selecting a song would require a display, user input, directory browsing capability, etc. which is easier to do with fi. an embedded PC board.
Old 28th October 2010, 08:10 PM   #29
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
+1 LeonvB
Old 28th October 2010, 08:40 PM   #30
A small microprocessor such as Arduino would be enough. But if you want to talk to the board, you will need i2c.
Russ said in post #8
"For now I have played signals up to 384khz directly from USB storage. But, I have not perfected this yet.
My hope is to be able to make the board work both as a host controller with USB storage and as a USB audio device. We shall see..."
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
Page generated in 0.10868 seconds (80.50% PHP - 19.50% MySQL) with 11 queries
