Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 2nd March 2011, 10:25 AM   #231
NicMac is offline NicMac  Italy
NicMac's Avatar
TPA - USB Transport
Originally Posted by Russ White View Post
As for the isolation, it is not caps. And it will not be on the USB board itself. It is a separate module.
The separate module(s)..... w/ I2S MUX (+ differential transmission modules for I2S (+I2C) over HDMI) and magnetic isolation
Old 2nd March 2011, 03:47 PM   #232
5th element is offline 5th element  United Kingdom
5th element's Avatar
Originally Posted by twest820 View Post
Works for me, as I expect I'd be following the L2 with an ADAU1445.
Doesn't work for me as I have a requirement for six channels of ASIO input. 44.1 would be fine though---the 1445's not short of ASRCs. Any chance of offering say, stereo @ <up to some high rate>, 4 channels @ <up to some high rate> / 2, 8 channels @ <up to some high rate> / 4?
I am assuming that you're going to be using the 1445 to create the crossover filters for an active loudspeaker setup. May I ask why you need 6 input channels? Surround sound?
You do realise that you only need to provide one stereo I2S stream to the 1445, then inside the DSP use the T connector, in sigmastudio, to split this off into as many stereo pairs as you want.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 3rd March 2011, 01:27 AM   #233
twest820 is offline twest820
A combination of per channel delay equalization and capabilities and pricing of currently available hardware. Time reversed IIR is not feasible on streaming DSPs and I've been unable to identify DSCs which can support it without requiring a little too much pain in some aspect of the implementation for me to find it worthwhile. A VisualDSP++ license for the audio SHARCs is probably the most elegant solution but is out of my budget. And, even if it were affordable, it wouldn't be competitive with a fanless PC on an NRE basis. The moreso in my case as I've already sunk the cost for reverse time VSTs and setting up Firewire audio interfaces.
Since my reverse time processing is unlikely to move off the PC any time soon it would be nice to simplify the ASIO -> Firewire -> audio interface -> SPDIF -> I2S part of the playback chain. Unfortunately xmon's current driver cost structure requires a DIY demand aggregator like Twisted Pear or exaDevices to be competitive. I could write my own device driver but, as that's not a way I particularly care to spend my free time, it's likely one of the two companies---if not both---will beat me to it.
Old 11th March 2011, 01:50 PM   #234
zkdaz is offline zkdaz  United Kingdom
I too had hoped it would be multi (8 or more) channel to do 4 way crossover and equalisation on the source PC which will be under utilised and capable of very fine meshed equalisation, rather than adding the complexity of an AD144x between receiver and DACs.
I was hoping to keep my build all TPA for simplicity but the exaDevices product would meet my requirements. As I am still in the planning phase of my project, I can only hope TPA xmos USB mkII might be multichannel and released before I finish building the rest.
Old 12th March 2011, 01:32 PM   #235
Russ White is online now Russ White  United States
Russ White's Avatar
Our plan is this:
Do a stereo board first and learn we can from it, then possibly to a multi channel version.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 12th March 2011, 08:27 PM   #236
LeonvB is offline LeonvB  Netherlands
Any idea about the ETA now you've settled for the XMOS chip?
Old 12th March 2011, 08:42 PM   #237
Russ White's Avatar
Lets just say I am planning an order of prototype PCBs in the next few days.
Audio
Old 12th March 2011, 09:11 PM   #238
thomaspf is offline thomaspf  United States
Getting 2 channel to work and learning in the process sounds pragmatic to me. Count on me for a preorder.
I can also offer driver stack knowledge for beta testing on Windows.
Cheers
Thomas
Old 13th March 2011, 06:40 AM   #239
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Can't wait to see some pics!
Old 22nd March 2011, 10:40 AM   #240
leifchristensen is offline leifchristensen  Norway
waiting is the one thing you should prepare for!
and you´re not alone
best
Leif
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 09:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 04:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 12:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 08:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 12:22 AM
