Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Closed Thread
Old 30th January 2011, 02:20 AM   #201
labjr is offline labjr  United States
Originally Posted by Russ White View Post
I am working on the layout today. I found out that the L1 chip was just not going to be able to handle what I wanted to do, so I switched to the L2. Otherwise it would be ready for protos by now.
So the L2 is a dual core?
Old 30th January 2011, 02:42 AM   #202
5th element is offline 5th element  United Kingdom
5th element's Avatar
XS1-L2 124QFN Package | XMOS
Looks that way.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 30th January 2011, 01:55 PM   #203
LeonvB is offline LeonvB  Netherlands
I vote for the G4. More memory
Old 30th January 2011, 02:10 PM   #204
Marek is offline Marek  Poland
Russ,
is it possible to integrate with TPA Transport I2C bus to connect to I2C of BuffaloII for remote software volume control (by ESS chip) eg via PC volume control?
Marek
Old 16th February 2011, 08:08 PM   #205
Anima is offline Anima  Denmark
Not alot happening here.. what's the status? I need it badly for my BII project..
Old 18th February 2011, 07:01 PM   #206
OllBoll is offline OllBoll  Sweden
A question for i2s masters...
If one used this usb-interface as master, does all slaves synchronize perfectly automatically?
What I wonder is if it would work fine to have both i2s and spdif output at the same time, spdif to an external flashy DAC but i2s to an Opus for subwoofer output.
Would both these DACs be perfectly synchronized without me having to do anything other than connect them correctly?
Or would multiple DACs complicate matters such that it would be better to skip the subwoofer dedicated Opus and instead use flashy dac output -> lowpass and then combine the for the subwoofer.
// Olle
Old 19th February 2011, 02:37 PM   #207
Russ White is offline Russ White  United States
Russ White's Avatar
Since I switched from L1 to L2 device I am just being extra careful verifying things because it is not an "app note" design. I am charting a new path for this device.
I have the layout mostly done, I am just working with XMOS and other to verify my work before I start to consume parts.
So yes there is progress.
Also please note there here are TPA we have several new modules in the works which we are extremely excited about. This is only one of those.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 19th February 2011, 03:42 PM   #208
Cheers!
Russ
Russ,
I hope i didn't seem ungrateful - i just feared that this would become postponed much more than it has. I see it's been set for November '10.. i don't mind waiting for quality, but a guy has to know when he can get his new toys
In your testing, have you been able to obtain 32 bit or is it "only" 24 bit? - i'm not going to take advantage of it, but i'm just really interested in the project.
Old 19th February 2011, 11:41 PM   #209
NicMac is offline NicMac  Italy
NicMac's Avatar
TPA - USB Transport
Default I2S RJ45 connector
Russ,
As the USB transport is also a very interesting "stand-alone" module for people to use between PC and DAC I was wondering if you could accommodate pads for a RJ45 connector for the I2S out using the same pinning as the (few) commercial DAC's that have I2S input (like North Star). And for those (few) of us already tapping DSD/I2S from SACD-players and sending it to the Buffalo using the CAT5/RJ45 interface.
Nic
Old 20th February 2011, 02:42 AM   #210
Hows the windows 7 support looking now? If I remember there were some issues regarding this.
Also will there be indicators (LEDs/output pins etc) anywhere that will show the sample rate? I'm going to want some kind of indicator that I can input into a microcontroller for system changes based on sampling frequency and something like that would be very useful.
Also what clock(ing scheme) will be used for the output?/What kind of jitter performance will this have? I expect this to be good anyway, I'm just curious I think lots of people are eagerly awaiting this project! And I just noticed this thread too.
Closed Thread
TPA - USB TransportHide this!Advertise here!
TPA metronome and Ivy modules woodturner-fran Swap Meet 7 29th January 2010 10:11 PM
TPA COD parts nikongod Swap Meet 6 8th January 2010 05:07 PM
A SD/USB/Ethernet transport jkeny Digital Line Level 8 25th September 2009 01:20 PM
Tpa 3122 help kkchunghk Class D 2 28th August 2009 09:44 AM
Maybe have a CD transport source USB to drive a USB DAC? wa2ise Digital Source 0 6th February 2007 01:22 AM
