#11 |
It will handle PCM(I2S) and SPDIF output too.
Less pulp more juice Twisted Pear Audio. |
#12 |
Well, I hope it's an I2S interface first and foremost. I wish the industry would retire S/PDIF.
#13 | |
Just use the one that suits your application best.
#14 |
Well, no one ever said anything about it actually, that's why I was hoping Russ would show a picture to us (referred to as "the kids") so we get an idea on how big it is as most of the people with Buffalo IIs have already assembled their boards and will have to rearrange them.
#15 |
The current plan is to try to make it the same size at the Buffalo module.
#16 |
Thanks so much!
#17 |
How could we combine this board with more traditional inputs like the Mux?
Should an Otto be used to switch between a Mux and the USB input? If so, can we expect the AC2 in the same timeframe to provide an easy switching capability? Or will a new module provide I2S passthrough/multiple SPDIF ports? |
#18 |
Those are two separate concerns. The USB module is simply that. USB in -> SPDIF/PCM out.
The OTTO will work to switch two I2S sources. You could also use the SPDIF from the USB module into the MUX. There is something else I am working on too, but it is too early to talk about it. Cheers! Russ
#19 | |
That would really finish my DAC
#20 |
space charged
Russ,
Have you considered incorporating an ADuM4160 USB Isolator as a front end? I've used that ahead of a Musiland USB to SP/DIF into my SABRE and noticed an improvement in sonics.
| Thread Tools | Search this Thread |
| TPA metronome and Ivy modules | woodturner-fran | Swap Meet | 7 | 29th January 2010 09:11 PM |
| TPA COD parts | nikongod | Swap Meet | 6 | 8th January 2010 04:07 PM |
| A SD/USB/Ethernet transport | jkeny | Digital Line Level | 8 | 25th September 2009 12:20 PM |
| Tpa 3122 help | kkchunghk | Class D | 2 | 28th August 2009 08:44 AM |
| Maybe have a CD transport source USB to drive a USB DAC? | wa2ise | Digital Source | 0 | 6th February 2007 12:22 AM |
