Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 11th December 2012, 03:50 PM   #401
zz1969 is offline zz1969  Russian Federation
Originally Posted by barrows View Post
folks have their Legatos now, lets hear some news. Here is what I am up to:
Balanced only, going to run from a single Placid BP. After having a look at the schematic I decided to eliminate as many steel leaded parts as I could, and do some other parts changes:
R5-8 will be "naked" Z-foils, the other .25 Watt resistors will be PRP. Caps, C9,10,13-15 will be Elna Silmic II (yes, one must get creative to fit them). C19-22 will be Amtrans. After searching for output coupling caps that will fit neatly in my chassis design, and (hopefully) be quite transparent, I have selected Mundorf Zn, 2.7 UF 100 V film/foil caps. The Zns are not cheap, but they cost nothing compared to a good interconnect. I am jumping the board cap mounts, and will wire the Zns to the terminal outputs and then directly to the XLRs.
I still have not decided if I am going to use the buffer stage or not. Russ advises not to with my partnering gear, and I know from a numbers perspective he is right, but I also like the idea of super low output impedance. Anyone have any feedback on whether or not the buffer stage is a good idea?
Barrows, are you happy with this parts tweak?
Old 12th March 2013, 06:20 PM   #402
icyjellybean is offline icyjellybean  Taiwan
From what I've read, a good amount of Legato tweakers use polystyrene or teflon filter caps. Have anyone used/considered C0G/NP0 caps in that position? Is it a good idea?
Old 12th March 2013, 06:37 PM   #403
kumori is offline kumori  Europe
From other people´s experience it is not a good idea to use ceramic caps in the signal path.
But your experience might vary.
I tried russion teflons, which gave a smooth and lean sound. I liked it at first but after switching to wima mkp10, I realized that it was quite boring. Some people also use Panasonic ECHU SMD caps with good results, which have minimal parasitic inductance due to their small size.
Old 12th March 2013, 11:39 PM   #404
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Legato Tweakers Thread...
I have had good results with C0G/NP0 caps, but they are limited to small values. I know people will disagree with that, but they have the right to be wrong
I have some polystyrene in either 10nF or 15nF (need to check) that I was experimenting with. Good results, but the supply was too unreliable to make kits with. Plus, I really like the Wima FKS.
Old 13th March 2013, 08:14 AM   #405
Thank you for sharing. Your experience with the Russian Teflons matches mine. They aren't bad, but seem to take some "life" out of the sound.
The Panasonic ECHU are interesting, I'll definitely look into it. I normally avoid messing with the PCB though, and adding legs seem to defeat the purpose.
Old 13th March 2013, 08:25 AM   #406
Hi Brian,
I believe you! The C0G/NP0 caps are one of a kind. I had my doubts, until a good friend of mine used one at the output of his Shigaclone transport. It's not just good, but better than the much pricier "big boys", V-Cap CuTF and Soshin SE99!
However, I've never used or heard one in an analog line stage before. Which brand/part did you use? How would you describe the sound, and do they match up to the oft-used film&foil for this application?
Thank you in advance!
Old 13th March 2013, 09:04 AM   #407
One more question: Are there any good replacements for the BC550B transistors? They seem quite hard to come by. Can I simply use BC550C instead, or are there better options?
Old 13th March 2013, 09:30 AM   #408
NicMac is offline NicMac  Italy
NicMac's Avatar
If somebody want to tweak I have just put up for sale some build Legato I/V stages here. I think the price should be very interesting.
Nic
Old 13th March 2013, 11:42 AM   #409
If I remember right I think you don´t have to modify the PCB for them.
They are large enough to solder them across the inner through-hole pads.
Old 13th March 2013, 01:34 PM   #410
Yes, BC550/560C are fine.
Legato Tweakers Thread...Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
One for Thorens tweakers Klimon Analogue Source 2 11th October 2008 09:05 PM
Priboi tweakers ? Zen Mod Tubes / Valves 4 14th May 2007 08:22 PM
Legato link dac chip,It reads data? Raj1 Digital Source 7 25th April 2007 11:25 AM
For all T-amp tweakers filholder Class D 13 14th July 2005 08:52 PM
